查看: 2562|回复: 0
[求助] ise map 时DCM警告
发表于 2012-10-18 10:59:25 | 显示全部楼层 |阅读模式
WARNING:NgdBuild:1212 - User specified non-default attribute value (100.000000)
   was detected for the CLKIN_PERIOD attribute on DCM "dcm/dcm_sp_inst".  This
   does not match the PERIOD constraint value (110 ns.).  The uncertainty
   calculation will use the non-default attribute value.  This could result in
   incorrect uncertainty calculated for DCM output clocks.
请问这个警告是啥意义?
GMT+8, 2025-12-21 23:51 , Processed in 0.013187 second(s), 5 queries , Gzip On, Redis On.
