查看: 4824|回复: 3
[求助] DC综合时出现 1 high-fanout nets
发表于 2012-10-16 16:35:56 | 显示全部楼层 |阅读模式
做DC综合时出现 1 high-fanout nets,如下:
Warning: Design 'VR_CS_TOP' contains 1 high-fanout nets. A fanout number of 1000 will be used for delay calculations involving these nets. (TIM-134)
     Net 'uVR_CS_DITHER/rstb': 1074 load(s), 1 driver(s)
"rstb"是复位信号,脚本设置如下:
create_clock -name pclk -period 30 -waveform [list 0 15] [get_ports pclk]
set_dont_touch_network [list pclk]
set_ideal_network -no_propagate  rstb
set_disable_timing [get_ports rstb]
求高手赐教,谢谢!
 楼主| 发表于 2012-10-16 17:51:56 | 显示全部楼层
自顶,在线等
发表于 2012-10-16 18:31:37 | 显示全部楼层
Dont care at DC.
Fix high fanout net at PR
 楼主| 发表于 2012-10-17 09:21:04 | 显示全部楼层
回复 3# q4949
    I'll have a try.Thank you!
GMT+8, 2025-12-28 09:42 , Processed in 0.017251 second(s), 5 queries , Gzip On, Redis On.
