查看: 2175|回复: 0
[原创] ISE PhysDesignRules AR#2100
发表于 2016-1-27 09:56:10 | 显示全部楼层 |阅读模式
PhysDesignRules:2100 - Issue with pin connections and/or configuration on
   block:<U_ila_pro_0/U0/I_NO_D.U_ILA/I_DQ.U_DQQ/DLY_9.DLY_9_GEN[39].I_SRLT_NE_0
   .DLY9/SRL16E>:<LUT_OR_MEM6>.  For RAMMODE programming set with DPRAM32,
   SPRAM32 or SRL16 the DI2 input pin must be connected.
在ISE生成bit文件时,产生了这个ERROR,不知道什么原因,请大家互相交流下。
GMT+8, 2025-12-30 16:15 , Processed in 0.017093 second(s), 6 queries , Gzip On, Redis On.
