查看: 8822|回复: 18
[求助] 第一次做lvs,有net连接的问题,实在不知道怎么办了。求前辈指点!!
发表于 2015-5-17 17:46:36 | 显示全部楼层 |阅读模式
做完lvs,有些错误自己能解决,还有一些问题实在是不知道哪里出错了,求助。这些错误好像都是IO pad的问题:(1)incorect nets
这两个net好像是pad内部的,不知道为什么错了
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net X4/X24/21                                             XPAD_IN_clk_sys/NET_9
       (_invv)ut                                               ** missing connection **
         X4/X24/X1/X103/X0/M0(89.235,384.745):s
         X4/X24/X1/M41(78.195,384.740):s
       X4/X24/X0/R16(73.115,388.405):neg                         ** missing connection **
       X4/X24/X0/R16(73.115,388.405):pos                         ** missing connection **
       ** missing connection **                                  (_invv)ut
        XPAD_IN_clk_sys/M_89:d
        XPAD_IN_clk_sys/M_90:d
  2    Net X21/X9/21                                             XPAD_IN_c/NET_9
         X21/X9/X1/X103/X0/M0(606.745,910.765):s
         X21/X9/X1/M41(606.740,921.805):s
       X21/X9/X0/R16(610.405,926.885):neg                        ** missing connection **
       X21/X9/X0/R16(610.405,926.885):pos                        ** missing connection **
       ** missing connection **                                  (_invv):out
        XPAD_IN_c/M_89:d
        XPAD_IN_c/M_90:d
(2)incorect instances
我在版图中看到是电阻的错误,也是IO内部的,不知道怎么回事?因为太多了,我就先粘贴两个吧
  INCORRECT INSTANCES
  3    X4/X24/X0/R16(73.115,388.405)  R(PR)                      ** missing instance **
  4    X4/X24/X0/R24(73.115,350.005)  R(PR)                      ** missing instance **
(3)property errors
这个错误提示的是source里面的电阻和layout里面的电阻值不匹配,这是怎么回事?(太多了,只粘贴两个吧)
PROPERTY ERRORS
DISC#  LAYOUT                                                    SOURCE                      ERROR
37    X4/X24/X0/R25(73.115,342.830)  R(PR)                      XPAD_IN_clk_sys/R_92  R
       r: 1785.22 ohm                                            r: 1725.31 ohm              3.47%
38    X4/X24/X0/X27/X17/R0(32.775,337.900)  R(PR)               XPAD_IN_clk_sys/R_93  R
       r: 981.331 ohm                                            r: 948.396 ohm              3.47%
求前辈们帮忙看看,这个周末就搞这个了,也没多大进展!谢谢大家了!!
具体的lvs报告在下面。
 楼主| 发表于 2015-5-17 19:11:06 | 显示全部楼层
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
  Error:    Connectivity errors.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
  Warning:  Ambiguity points were found and resolved arbitrarily.
LAYOUT CELL NAME:         clk_test
SOURCE CELL NAME:         clk_test
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             11        11
Nets:             353       329    *
Instances:        988       800    *    MN (4 pins)
                   877       593    *    MP (4 pins)
                   174        24    *    R (2 pins)
                   136        16    *    D (2 pins)
                     0         4    *    PCORNER (0 pins)
Total Inst:      2175      1437
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             11        11
Nets:             251       251
Instances:         81        81         MN (4 pins)
                   123       123         MP (4 pins)
                    54        24    *    R (2 pins)
                    12        12         D (2 pins)
                    76        76         _invv (4 pins)
                    13        13         _invx2v (4 pins)
                     5         5         _invx3v (4 pins)
                     1         1         _invx4v (4 pins)
                     6         6         _nand2v (5 pins)
                     6         6         _nor2v (5 pins)
                    36        36         _pdw2v (4 pins)
                     6         6         _pdw3v (5 pins)
                     6         6         _pup3v (5 pins)
                    12        12         _sdw2v (4 pins)
                     6         6         _sdw3v (5 pins)
                    16        16         _sup2v (4 pins)
Total Inst:       459       433
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
        XPAD_IN_c/M_89:d
        XPAD_IN_c/M_90:d
                                 INCORRECT INSTANCES
  5    X4/X24/X0/R26(73.115,337.560)  R(PR)                      ** missing instance **
  6    X4/X24/X0/X27/X10/R1(33.365,387.180)  R(PR)               ** missing instance **
  7    X4/X24/X0/X27/X16/R1(33.365,344.940)  R(PR)               ** missing instance **
  8    X4/X25/X0/R16(73.115,664.405)  R(PR)                      ** missing instance **
  9    X4/X25/X0/R24(73.115,626.005)  R(PR)                      ** missing instance **
10    X4/X25/X0/R26(73.115,613.560)  R(PR)                      ** missing instance **
11    X4/X25/X0/X27/X10/R1(33.365,663.180)  R(PR)               ** missing instance **
12    X4/X25/X0/X27/X16/R1(33.365,620.940)  R(PR)               ** missing instance **
13    X21/X9/X0/R16(610.405,926.885)  R(PR)                     ** missing instance **
14    X21/X9/X0/R24(572.005,926.885)  R(PR)                     ** missing instance **
15    X21/X9/X0/R26(559.560,926.885)  R(PR)                     ** missing instance **
16    X21/X9/X0/X27/X10/R1(609.180,966.635)  R(PR)              ** missing instance **
17    X21/X9/X0/X27/X16/R1(566.940,966.635)  R(PR)              ** missing instance **
18    X23/X7/X0/R16(776.405,926.885)  R(PR)                     ** missing instance **
19    X23/X7/X0/R24(738.005,926.885)  R(PR)                     ** missing instance **
20    X23/X7/X0/R26(725.560,926.885)  R(PR)                     ** missing instance **
21    X23/X7/X0/X27/X10/R1(775.180,966.635)  R(PR)              ** missing instance **
22    X23/X7/X0/X27/X16/R1(732.940,966.635)  R(PR)              ** missing instance **
23    X28/X16/X0/R16(926.885,265.095)  R(PR)                    ** missing instance **
24    X28/X16/X0/R24(926.885,303.495)  R(PR)                    ** missing instance **
25    X28/X16/X0/R26(926.885,315.940)  R(PR)                    ** missing instance **
26    X28/X16/X0/X27/X10/R1(966.635,266.320)  R(PR)             ** missing instance **
27    X28/X16/X0/X27/X16/R1(966.635,308.560)  R(PR)             ** missing instance **
28    X28/X17/X0/R16(926.885,472.595)  R(PR)                    ** missing instance **
29    X28/X17/X0/R24(926.885,510.995)  R(PR)                    ** missing instance **
30    X28/X17/X0/R26(926.885,523.440)  R(PR)                    ** missing instance **
31    X28/X17/X0/X27/X10/R1(966.635,473.820)  R(PR)             ** missing instance **
32    X28/X17/X0/X27/X16/R1(966.635,516.060)  R(PR)             ** missing instance **
33    ** missing instance **                                    XCORNER1  PCORNER
34    ** missing instance **                                    XCORNER2  PCORNER
35    ** missing instance **                                    XCORNER3  PCORNER
36    ** missing instance **                                    XCORNER4  PCORNER
                                      PROPERTY ERRORS
39    X4/X24/X1/R89(77.415,334.430)  R(PR)                      XPAD_IN_clk_sys/R_91  R
       r: 257.44 ohm                                             r: 248.8 ohm                3.47%
40    X4/X25/X0/R25(73.115,618.830)  R(PR)                      XPAD_IN_a/R_92  R
41    X4/X25/X0/X27/X17/R0(32.775,613.900)  R(PR)               XPAD_IN_a/R_93  R
42    X4/X25/X1/R89(77.415,610.430)  R(PR)                      XPAD_IN_a/R_91  R
43    X6/X7/X25/R14(224.420,47.280)  R(PR)                      XV181/R_67  R
       r: 1.37519e+06 ohm                                        r: 1.32904e+06 ohm          3.47%
44    X9/X7/X25/R14(277.580,952.720)  R(PR)                     XV182/R_67  R
45    X18/X10/R108(555.920,54.710)  R(PR)                       XV33/R_3  R
       r: 3.40499e+06 ohm                                        r: 3.29071e+06 ohm          3.47%
46    X18/X11/R20(561.885,77.915)  R(PR)                        XV33/R_4  R
       r: 787.162 ohm                                            r: 760.744 ohm              3.47%
47    X21/X9/X0/R25(564.830,926.885)  R(PR)                     XPAD_IN_c/R_92  R
48    X21/X9/X0/X27/X17/R0(559.900,967.225)  R(PR)              XPAD_IN_c/R_93  R
49    X21/X9/X1/R89(556.430,922.585)  R(PR)                     XPAD_IN_c/R_91  R
50    X23/X7/X0/R25(730.830,926.885)  R(PR)                     XPAD_IN_clk_i2c/R_92  R
51    X23/X7/X0/X27/X17/R0(725.900,967.225)  R(PR)              XPAD_IN_clk_i2c/R_93  R
52    X23/X7/X1/R89(722.430,922.585)  R(PR)                     XPAD_IN_clk_i2c/R_91  R
53    X28/X16/X0/R25(926.885,310.670)  R(PR)                    XPAD_OUT_e/R_92  R
54    X28/X16/X0/X27/X17/R0(967.225,315.600)  R(PR)             XPAD_OUT_e/R_93  R
55    X28/X16/X1/R89(922.585,319.070)  R(PR)                    XPAD_OUT_e/R_91  R
56    X28/X17/X0/R25(926.885,518.170)  R(PR)                    XPAD_OUT_b/R_92  R
57    X28/X17/X0/X27/X17/R0(967.225,523.100)  R(PR)             XPAD_OUT_b/R_93  R
58    X28/X17/X1/R89(922.585,526.570)  R(PR)                    XPAD_OUT_b/R_91  R
59    X28/X18/R108(945.290,680.420)  R(PR)                      XV33ON/R_3  R
60    X28/X19/R20(922.085,686.385)  R(PR)                       XV33ON/R_4  R
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:              11         11            0            0
   Nets:              251        251            0            0
   Instances:          20         20            0            0    MN(n)
                       61         61            0            0    MN(ND)
                       24         24            0            0    MP(p)
                       99         99            0            0    MP(PD)
                       24         24           30            0    R(PR)
                        2          2            0            0    D(D1)
                        6          6            0            0    D(DB)
                        3          3            0            0    D(dn)
                        1          1            0            0    D(DP)
                        0          0            0            4    PCORNER
                       76         76            0            0    _invv
                       13         13            0            0    _invx2v
                        5          5            0            0    _invx3v
                        1          1            0            0    _invx4v
                        6          6            0            0    _nand2v
                        6          6            0            0    _nor2v
                       36         36            0            0    _pdw2v
                        6          6            0            0    _pdw3v
                        6          6            0            0    _pup3v
                       12         12            0            0    _sdw2v
                        6          6            0            0    _sdw3v
                       16         16            0            0    _sup2v
   Total Inst:        429        429           30            4
o Statistics:
   1525 layout mos transistors were reduced to 336.  18 connecting nets were deleted.
     1153 mos transistors were deleted by parallel reduction.
     36 mos transistors and 18 connecting nets were deleted by split-gate reduction.
   772 source mos transistors were reduced to 55.
     717 mos transistors were deleted by parallel reduction.
   140 series/parallel layout resistors were reduced to 20.  6 connecting nets were deleted.
   135 parallel layout diodes were reduced to 11.
   8 parallel source diodes were reduced to 4.
   13 nets and 2 instances were matched arbitrarily.
o Initial Correspondence Points:
   Ports:        VDD VDDPST VSS VSSPST POC clk_sys a c clk_i2c e b
o Ambiguity Resolution Points:
      (Each one of the following objects belongs to a group of indistinguishable objects.
       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
       Layout                                                    Source
                                     Nets
       X6/X7/14                                                  XV181/NET_0
       X18/X10/12                                                XV33/NET_3
       X4/X24/X1/44                                              XPAD_IN_c/NET_17
       X23/X7/X1/44                                              XPAD_IN_clk_i2c/NET_17
       X4/X25/X1/44                                              XPAD_IN_a/NET_17
       X4/X25/X1/45                                              XPAD_IN_a/NET_26
       X4/X24/X1/45                                              XPAD_IN_clk_sys/NET_26
       X21/X9/X1/45                                              XPAD_IN_c/NET_26
       X21/X9/X1/24                                              XPAD_IN_clk_sys/NET_21
       X23/X7/X1/24                                              XPAD_OUT_b/NET_21
       X28/X17/X1/24                                             XPAD_IN_clk_i2c/NET_21
       X4/X24/X1/24                                              XPAD_IN_c/NET_21
       X28/X16/X1/24                                             XPAD_OUT_e/NET_21
                                   Instances
       (_invx2v)                                                 (_invx2v)
       Devices:
         X28/X19/M9(922.470,705.185)  MP(PD)                       XV33ON/M_30  MP(PD)
         X28/X19/X40/X0/M0(911.375,705.160)  MN(ND)                XV33ON/M_126  MN(ND)
         X28/X19/M15(922.470,718.265)  MP(PD)                      XV33ON/M_31  MP(PD)
         X28/X19/X43/X0/M0(911.375,718.240)  MN(ND)                XV33ON/M_122  MN(ND)
       (_invx2v)                                                 (_invx2v)
       Devices:
         X18/X11/M9(580.685,77.530)  MP(PD)                        XV33/M_34  MP(PD)
         X18/X11/X40/X0/M0(580.660,88.625)  MN(ND)                 XV33/M_125  MN(ND)
         X18/X11/M15(593.765,77.530)  MP(PD)                       XV33/M_29  MP(PD)
         X18/X11/X43/X0/M0(593.740,88.625)  MN(ND)                 XV33/M_121  MN(ND)
o Matched Mosfets Which Have Been Unequally Reduced:
       X28/X19/M15(922.470,718.265)                              XV33ON/M_31
       X28/X19/M16(922.470,719.235)                              XV33ON/M_32
       X28/X19/M17(922.470,722.625)                              ** missing smashed mosfet **
       X28/X19/M18(922.470,723.595)                              ** missing smashed mosfet **
       X28/X19/X43/X0/M0(911.375,718.240)                        XV33ON/M_122
       X28/X19/X43/X1/M0(911.375,719.210)                        XV33ON/M_123
       X28/X19/X44/X0/M0(911.375,722.600)                        ** missing smashed mosfet **
       X28/X19/X44/X1/M0(911.375,723.570)                        ** missing smashed mosfet **
       X28/X19/M11(922.470,709.545)                              XV33ON/M_35
       X28/X19/M12(922.470,710.515)                              XV33ON/M_36
       X28/X19/M13(922.470,713.905)                              ** missing smashed mosfet **
       X28/X19/M14(922.470,714.875)                              ** missing smashed mosfet **
       X28/X19/X41/X0/M0(911.375,709.520)                        XV33ON/M_37
       X28/X19/X41/X1/M0(911.375,710.490)                        XV33ON/M_132
       X28/X19/X42/X0/M0(911.375,713.880)                        ** missing smashed mosfet **
       X28/X19/X42/X1/M0(911.375,714.850)                        ** missing smashed mosfet **
       X18/X11/M15(593.765,77.530)                               XV33/M_29
       X18/X11/M16(594.735,77.530)                               XV33/M_36
       X18/X11/M17(598.125,77.530)                               ** missing smashed mosfet **
       X18/X11/M18(599.095,77.530)                               ** missing smashed mosfet **
       X18/X11/X43/X0/M0(593.740,88.625)                         XV33/M_121
       X18/X11/X43/X1/M0(594.710,88.625)                         XV33/M_122
       X18/X11/X44/X0/M0(598.100,88.625)                         ** missing smashed mosfet **
       X18/X11/X44/X1/M0(599.070,88.625)                         ** missing smashed mosfet **
       X18/X11/M11(585.045,77.530)                               XV33/M_30
       X18/X11/M12(586.015,77.530)                               XV33/M_32
       X18/X11/M13(589.405,77.530)                               ** missing smashed mosfet **
       X18/X11/M14(590.375,77.530)                               ** missing smashed mosfet **
       X18/X11/X41/X0/M0(585.020,88.625)                         XV33/M_123
       X18/X11/X41/X1/M0(585.990,88.625)                         XV33/M_128
       X18/X11/X42/X0/M0(589.380,88.625)                         ** missing smashed mosfet **
       X18/X11/X42/X1/M0(590.350,88.625)                         ** missing smashed mosfet **
                             DETAILED INSTANCE CONNECTIONS
          (This section contains detailed information about connections of
           matched instances that are involved in net discrepancies).
       (_invv)                                                   (_invv)
         in: X4/X24/X1/37                                          in: XPAD_IN_c/NET_18
         sup1: VDDPST                                              sup1: VDDPST
         sup2: VSS                                                 sup2: VSS
         out: X4/X24/21                                            ** XPAD_IN_clk_sys/NET_9 **
         ** X21/X9/21 **                                           out: XPAD_IN_c/NET_9
       Devices:
         X4/X24/X1/M41(78.195,384.740)  MP(PD)                     XPAD_IN_c/M_90  MP(PD)
         X4/X24/X1/X103/X0/M0(89.235,384.745)  MN(ND)              XPAD_IN_c/M_89  MN(ND)
       (_invv)                                                   (_invv)
         in: X21/X9/X1/37                                          in: XPAD_IN_clk_sys/NET_18
         sup2: VSS                                                 sup2: VSS
         out: X21/X9/21                                            ** XPAD_IN_c/NET_9 **
         ** X4/X24/21 **                                           out: XPAD_IN_clk_sys/NET_9
       Devices:
         X21/X9/X1/M41(606.740,921.805)  MP(PD)                    XPAD_IN_clk_sys/M_90  MP(PD)
         X21/X9/X1/X103/X0/M0(606.745,910.765)  MN(ND)             XPAD_IN_clk_sys/M_89  MN(ND)
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
 楼主| 发表于 2015-5-18 09:06:29 | 显示全部楼层
顶!!
发表于 2015-5-18 09:10:10 | 显示全部楼层
PCORNER从netlist中拿掉
检查下电阻是从那里多出来的
 楼主| 发表于 2015-5-18 09:25:53 | 显示全部楼层
回复 4# damonzhao
您的意思是(1)incorrect net是和CORNER有关系?我先拿掉试试看
(2)我基本上能确定电阻都是在IO pad里面多出来的,这是我第一个关于incorrect instances的错误,R16。是版图里面有,source里面missing。版主,我怎么觉得这个电阻是短路的呢?还有下面的好多个。
 楼主| 发表于 2015-5-18 09:33:02 | 显示全部楼层
回复 4# damonzhao
版主,把corner从netlist中拿掉后,那四个(我用了四个corner)关于corner的错误没了,其他的net错误还在,没变化。
发表于 2015-5-18 10:01:55 | 显示全部楼层
先检查  电源  和 地  连接  是否正确???
 楼主| 发表于 2015-5-18 10:06:34 | 显示全部楼层
回复 7# xxtop
正确。报告里面之前有关于power 和 ground的错误,已经解决了。没有打pin
发表于 2015-5-18 11:14:17 | 显示全部楼层
谢分享,学习了
 楼主| 发表于 2015-5-18 11:28:17 | 显示全部楼层
版主们还在吗?
GMT+8, 2025-12-16 06:38 , Processed in 0.028119 second(s), 6 queries , Gzip On, Redis On.
