查看: 5238|回复: 2
[求助] Formality:对含有FF的设计做Formality,为什么都报FF failing
发表于 2014-12-11 14:36:55 | 显示全部楼层 |阅读模式
做了几个时序电路的formality,发现都是FF failing,找不出什么原因,请前辈帮忙,谢谢
设置:
  1 ##
  2 set hdlin_ignore_full_case true
  3 set hdlin_ignore_parallel_case false
  4 set hdlin_warn_on_mismatch_message "FMR_ELAB-147"
  5 set hdlin_error_on_mismatch_message true
  6 set hdlin_unresolved_modules black_box
  7 set hdlin_enable_hier_naming true
  8 set verification_set_undriven_signals X
  9 set verification_constant_prop_mode auto
10 man enable_multiplier_generation
1179     Compare point 269/FFY/ASYNC_FF failed (is not equivalent)
1180     Compare point 147/FFX/ASYNC_FF failed (is not equivalent)
1181     Compare point 298/FFY/ASYNC_FF failed (is not equivalent)
1182     Compare point 299/FFY/ASYNC_FF failed (is not equivalent)
1183     Compare point 300/FFY/ASYNC_FF failed (is not equivalent)
1184     Compare point 301/FFY/ASYNC_FF failed (is not equivalent)
1185     Compare point 291/FFY/ASYNC_FF failed (is not equivalent)
1186     Compare point 302/FFY/ASYNC_FF failed (is not equivalent)
1187
1188 ********************************* Verification Results *********************************
1189 Verification FAILED
1190 -------------------
1191  Reference design: r:/WORK/divider_dshift
1192  Implementation design: i:/WORK/divider_dshift
1193  590 Passing compare points
1194  20 Failing compare points
1195  0 Aborted compare points
1196  72 Unverified compare points
1197 ----------------------------------------------------------------------------------------
1198 Matched Compare Points     BBPin    Loop   BBNet     Cut    Port     DFF     LAT   TOTAL
1199 ----------------------------------------------------------------------------------------
1200 Passing (equivalent)            260       0          0          0        65      265       0     590
1201 Failing (not equivalent)         0          0          0          0        0        20         0      20
1202 Unverified                           0          0          0          0        0        72         0      72
1203 ****************************************************************************************
发表于 2014-12-11 16:50:49 | 显示全部楼层
FF是什么东西?
 楼主| 发表于 2014-12-12 08:47:49 | 显示全部楼层
回复 2# ibrotherv1
FF 就是DFF,谢谢
GMT+8, 2025-12-30 00:10 , Processed in 0.019185 second(s), 5 queries , Gzip On, Redis On.
