查看: 2386|回复: 2
[原创] generated clock设置问题
发表于 2014-10-17 00:15:42 | 显示全部楼层 |阅读模式
Picture shows an example where the clockSYS_CLKis gated by the
output of a flip-flop. Since the output of the flip-flop may not be a constant,
one way to handle this situation is to define a generated clock at the output
of theandcell which is identical to the input clock.
将门控时钟设置成generated clock在STA操作中有什么好处和作用?求大神解答~~~
发表于 2014-10-17 15:01:15 | 显示全部楼层
1,利于分析UAND1的两个输入端的时序是否满足(若不满足则可能在CORE_CLK上产生glitch)
2,利于分析SYS_CLK和CORE_CLK这两个时钟域之间的path
楼下补充
发表于 2014-10-21 13:34:58 | 显示全部楼层
是不是也可以方便得到源clock的latency
GMT+8, 2025-12-18 11:11 , Processed in 0.023347 second(s), 6 queries , Gzip On, Redis On.
