查看: 3773|回复: 2
[求助] tsuprem仿真IGBT的翻转后找不到表面exposed的问题
发表于 2014-4-29 12:01:04 | 显示全部楼层 |阅读模式
$2 initialize
initialize <100> phosphor=220resistiv
load in.f=out1 flip.y
implant phos dose=1e12 energy=120 tilt=0
Diffusion time=1200 temp=1225 weto2
load in.f=out.100 flip.y
$set field Oxide
*** Warning:  There is no exposed surface; no oxidationwill occur.
在mesh和initial以后,把器件翻转过来进行注入和扩散,会提示找不到表面,定义了boudary以后,这一步注入和扩散能正常进行了,但是接下来我要长场氧的工艺就又出现错误,求大牛指教啊!
$3 set field oxide
Diffusion time=30 temp=750 t.final=900 nitro
Time: current = 0         delta = 0.002     new = 0.002      Nodes: 17498
Time: current = 0.002     delta = 0.1469    new = 0.1489     Nodes: 17498
Time: current = 0.1489    delta = 10        new = 10.15      Nodes: 17498
Time: current = 10.15     delta = 10        new = 20.15      Nodes: 17498
Time: current = 20.15     delta = 9.851     new = 30         Nodes: 17498
Diffusion time=10 temp=900 f.n2=8 f.o2=2
*** Error:  triangle 34240 is flat
*** The remainder of the file will not be executed, ***
***    but it will be checked for correct syntax.   ***
-> Node   Location (um)
   17498   (              0,     10.9999999)
      82   (     0.50469047,     10.9999999)
       0   (              0,     10.9999999)
***   tri_geom called from geom
*** Fatal internal error
*     Error ID:  During geometry calculation
*     Program Version:  2010.3.0/K
*** Please report this error to Synopsys TCAD so we can correct it.  Please include
*     the Error ID and Program Version given above and a listing of any
*     preceding messages.  If possible, send a copy of the input file that
*     produced the error.  Thank you.
*** Execution terminated.
发表于 2014-5-16 10:38:28 | 显示全部楼层
回复 1# wlm
网格有问题,所以会出现triangle的问题。
发表于 2014-6-23 15:46:04 | 显示全部楼层
这个问题我也遇到过。
TS4只能定义一面为曝光面(上下左右),而且整个程序过程中不能更改,因此翻转后曝光面不变。
建议:单独仿真背部,提取杂质分布。然后在MEDICI中直接定义掺杂分布。
GMT+8, 2025-12-27 13:33 , Processed in 0.016770 second(s), 9 queries , Gzip On, Redis On.
