查看: 8152|回复: 3
[原创] unable to resolve the reference的解决方法
发表于 2014-2-27 10:21:43 | 显示全部楼层 |阅读模式
最近在学习综合,遇到以上问题,终于得以解决,解决方法参考网址http://www.edaboard.com/thread32557.html
  • How to resolve multiple instance in DC
  • a module with parameter such as:
    module encrypt(
    data_in, // data input
    data_out, // data output
    mpt // configuration data
    parameter datalen = 24;
    input [datalen-1:0] data_in;
    input [datalen-1:0] mpt;
    output [datalen-1:0] data_out;
    reference the design encrypt several times with different parameter.
    using uniquify command in DC can't resolve the problem ,the report is the following.
    Error: 'encrypt' was not identified as a synthetic library module
    and could not be successfully elaborated from design library 'WORK'. (LINK-10)
    Warning: Unable to resolve reference 'encrypt' in 'cmem_if'. (LINK-
Re: How to resolve multiple instance in DC
  • Set this variable and tryout...
    hdlin_auto_save_templates = "TRUE"
    Hope this will help!
I think you shall check your scripts and codes first .Make sure where it's the point.
I think you'd better to refer to the DC User Guide!
Maybe the following description help you:
current_design design_top
uniquify // to resolve multiple instances in DC
compile
Hi, xiongdh
Please check your instance names for this module.
Good Luck
  • //the following dc script resolved this problem.
    define_design_lib work -path ./WORK
    analyze -f verilog encrypt.v
    analyze -f verilog code_vir2phy.v
    analyze -f verilog cmem_if.v
    elaborate cmem_if
    current_design = cmem_if
    /*uniquify because of the mig boundary cells */
    uniquify
    link
    compile
  • yes, refer to user guide and check your script.
    good luck
OKay, Please check your scripts and first compiler it!
发表于 2018-10-24 20:32:54 | 显示全部楼层
赞一个
发表于 2021-6-16 15:41:50 | 显示全部楼层
所以怎么解决多次例化的问题
发表于 2025-1-13 10:33:21 | 显示全部楼层
jojenwong 发表于 2021-6-16 15:41
所以怎么解决多次例化的问题
uniquify
GMT+8, 2025-12-17 12:15 , Processed in 0.017798 second(s), 5 queries , Gzip On, Redis On.
