查看: 3352|回复: 4
[求助] 安装ISE后无法启动PlanAhead
发表于 2013-11-19 08:17:30 | 显示全部楼层 |阅读模式
安装的ISE14.7,但是PlanAhead启动不了。在cmd窗口显示 start gui 之后,软件启动画面一闪而过。
在日志中有如下的记录,请问这个问题怎么解决呢?
多谢大神赐教!
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007fbef331355, pid=8840, tid=8096
# JRE version: 7.0_17-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.7-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [msvcrt.dll+0x1355]  free_dbg+0x5
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
发表于 2013-11-19 09:39:26 | 显示全部楼层
看提示啊,JRE装一下,
 楼主| 发表于 2013-11-19 12:38:16 | 显示全部楼层
回复 2# eaglelsb
已经装了,还是不行。。
发表于 2013-11-21 15:29:36 | 显示全部楼层
有没有试着重新安装下?
发表于 2014-2-23 00:42:10 | 显示全部楼层
good idea
GMT+8, 2025-12-21 01:34 , Processed in 0.015815 second(s), 3 queries , Gzip On, Redis On.
