查看: 2430|回复: 4
[求助] 关于verilog的问题,求大神解答
发表于 2013-11-8 12:14:37 | 显示全部楼层 |阅读模式
我要写一个简单的电梯控制verilog。我想问问这样写有什么问题吗?谢谢。
module semester(
  input  [3:0]w,
  input Clock,
  input switch,
    output  first,
    output  second,
    output  third,
    output  fourth
  reg [2:0] y;
  reg [1:0] counter;
  initial begin
  counter=00;
  y=001;
  end
  parameter [2:0] A = 3'b000, B = 3'b001, C = 3'b010, D= 3'b011,E=3'b100,F=3'b101,G=3'b110,H=3'b111;
always@ (posedge Clock)begin
case (y)
A:
  if(w==0001|switch==1) begin
   y<=A;
   counter=00;
  end
  else if(!counter==11&(w==0000|w==0010|w==0100|w==1000)&switch==0)
   counter=counter+1;
  else if(counter==11&(w==0000|w==0010|w==0100|w==1000)&switch==0) begin
   y<=B;
   counter=00;
  end
B:
  if(w==0000)
   y<=B;
  else if(w==0001)
   y<=A;
  else if((w==0010|w==0100|w==1000)&!counter==01)
   counter=counter+1;
  else if((w==0010|w==0100|w==1000)&counter==01) begin
   y<=D;
   counter=00;
   end
C:
  if(w==0010|switch==1) begin
   y<=C;
   counter=00;
  end
  else if((w==0000|w==0001|w==0100|w==1000)&!counter==11&switch==0)
   counter=counter+1;
  else if((w==0000|w==0001|w==0100|w==1000)&counter==11&switch==0)begin
   y<=D;
   counter=00;
  end
D:
  if(w==0000)
   y<=D;
  else if(w==0010)
   y<=C;
  else if((w==0001|w==0100|w==1000)&!counter==01)
   counter=counter+1;
  else if(w==0001&counter==01) begin
   y<=B;
   counter=00;
  end
  else if((w==0100|w==1000)&counter==01) begin
   y<=F;
   counter=00;
  end
E:
  if(w==0100|switch==1) begin
   y<=E;
   counter=00;
  end
  else if((w==0000|w==0001|w==0010|w==0100)&!counter==11&switch==0)
   counter=counter+1;
  else if((w==0000|w==0001|w==0010|w==0100)&counter==11&switch==0)begin
   y<=F;
   counter=00;
  end
F:
  if(w==0000)
   y<=F;
  else if(w==0100)
   y<=E;
  else if((w==001|w==0010|w==1000)&!counter==01)
   counter=counter+1;
  else if((w==0001|w==0010)&counter==01) begin
   y<=D;
   counter=00;
  end
  else if(w==1000&counter==01) begin
   y<=H;
   counter=00;
   end
G:
  if(w==1000|switch==1) begin
   y<=G;
   counter=00;
  end
   counter=counter+1;
  else if((w==0000|w==0001|w==0010|w==0100)&counter==11&switch==0) begin
   y<=H;
   counter=00;
  end
H:
  if(w==0000)
   y<=H;
  else if(w==1000)
   y<=G;
  else if((w==0001|w==0010|w==0100)&!counter==01)
   counter=counter+1;
  else if((w==0001|w==0010|w==0100)&!counter==01) begin
   y<=F;
   counter=00;
   end
  default y<=3'bxxx;
endcase
end
assign first=~y[0]&~y[1]&~y[2];
assign second=!y[0]&y[1]&!y[2];
assign third=!y[0]&!y[1]&y[2];
assign fourth=!y[0]&y[1]&y[2];
endmodule
发表于 2013-11-8 12:29:47 | 显示全部楼层
大概看了下
这个只能仿真吧。。initial 这种不能综合吧
W==0010这种要写成显式。比如W= 4'b0010
default后面加冒号。
阻塞和非阻塞赋值不要弄在一个always里面
 楼主| 发表于 2013-11-8 12:53:14 | 显示全部楼层
回复 2# sonson2008
    非常感谢。
发表于 2013-11-8 14:24:24 | 显示全部楼层
回复 3# swis
    可以考虑加根复位信号,然后把initial里的东西扔里面
发表于 2013-11-8 23:33:38 | 显示全部楼层
四层楼,为什么用八个状态?
另外,这是什么意思?
!counter==11 什么意思? do you mean (count!=2'b11)???
这样写,太难读了。。。
GMT+8, 2025-12-26 04:31 , Processed in 0.015002 second(s), 6 queries , Gzip On, Redis On.
