查看: 3999|回复: 4
有没有人知道FEKO和谐版新年过后运行显示系统时间错误导致无法运行
发表于 2013-2-26 19:25:20 | 显示全部楼层 |阅读模式
问题显示: ERROR  9010:
   Invalid system date 2013-02-26 (Code 197248).
   Please make sure that the date on your computer is set correctly. If this
    error persists, try to re-boot your computer after the date correction.
Used licence file with path:
           Not available
Used licence number:  Not available
Machine codes for host "hp-PC":
           Not available
Should you need further assistance or an updated licence file
"secfeko.dat", please contact your FEKO distributor or the FEKO
support team and provide the complete output above including the
error number.
If you are unsure about your contact point, then please use these
e-mail addresses:
    feko_license@emssusa.com   for North America
    feko_license@emss.de       for Europe
    feko_license@emss.co.za    for all other regions
哪位大侠知道怎么办,我把时间改成去年也不成,不知道怎么办啊,跪求解决方法,急用!
 楼主| 发表于 2013-2-26 19:27:33 | 显示全部楼层
防沉,自己顶起来
发表于 2013-4-13 20:36:07 | 显示全部楼层
FEKO是啥?从来没听说过。
发表于 2013-12-24 20:34:33 | 显示全部楼层
求6.3 crack
发表于 2015-9-10 10:01:56 | 显示全部楼层
楼主,你的问题解决了吗,我也碰到了类似的问题
GMT+8, 2025-10-18 07:17 , Processed in 0.018611 second(s), 7 queries , Gzip On, Redis On.
