查看: 19571|回复: 27
[求助] 关于DC license 问题
发表于 2010-5-22 16:50:55 | 显示全部楼层 |阅读模式
运行了License以后,log file出现如下问题:
1:30:39 (lmgrd) License file(s): /home/ggzhuq/eda/synopsys/license/synopsys.dat
1:30:39 (lmgrd) lmgrd tcp-port 27000
1:30:39 (lmgrd) Starting vendor daemons ...
1:30:39 (lmgrd) Started snpslmd (internet tcp_port 32926 pid 8817)
[ggzhuq@qizhu ~]$  1:30:40 (snpslmd) FLEXnet Licensing version v10.8.5.3 build 59306 i86_re3
01:30:40 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.3
1:30:40 (snpslmd) Server started on qizhu for: SSS
1:30:40 (snpslmd)
1:30:40 (snpslmd) Licenses are case sensitive for TE_CATS
1:30:40 (snpslmd)
1:30:40 (snpslmd) EXTERNAL FILTERS are OFF
1:30:40 (lmgrd) snpslmd using TCP-port 32926
1:30:40 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9 ssilmd  synopsysd  tmald  vcsd
01:30:41 (snpslmd) ------------------------------------------------------------------
01:30:41 (snpslmd) Checking the integrity of the license file....
01:30:41 (snpslmd) Valid SSS feature found. INVALID license file fingerprint.
01:30:41 (snpslmd) The feature is needed to enable the other keys in your license file.
license应该起来了吧?
在终端运行dv时有如下错误:
Unable to obtain feature 'Design-Vision ' because:
Error: Can't communicate with the license server. (SEC-12)
这是什么原因啊?那位大侠能否指导下,这里先行谢过了。(license验证已经通过)
发表于 2010-5-22 23:33:49 | 显示全部楼层
licence没有启动成功吧,最后那都说了“INVALID”.
 楼主| 发表于 2010-5-23 00:22:53 | 显示全部楼层
2# nltc
INVALID license file fingerprint , 这个可能是删掉其它feacture,会出现的吧,环境变量跟license都是完全按照论坛上的教程做的,感觉问题不会出在这里,会不是是系统配置有问题?
 楼主| 发表于 2010-5-23 22:34:07 | 显示全部楼层
没有人回复吗?最近是在很急,麻烦有知道的回复下,谢谢了!
发表于 2010-6-27 00:45:24 | 显示全部楼层
4# ggzhuq
i meet the same question .
发表于 2012-8-2 17:38:14 | 显示全部楼层
同问啊!!!
发表于 2012-8-2 20:59:47 | 显示全部楼层
Feature wrong,version is too new
发表于 2013-4-3 10:28:42 | 显示全部楼层
有相同的问题
发表于 2013-9-14 15:31:41 | 显示全部楼层
End dates have been modified.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
License file integrity check FAILED!
我出现的错误是这样的,输出DC和DV都能进入dc_shell和图形化界面的DV,是不是依然不能使用,没有破解成功?求大牛帮忙!!!!!
发表于 2014-10-23 13:41:36 | 显示全部楼层
License file integrity check FAILED!   同问  采用 论坛上给的破解方法  下了好几个版本的license都这个提示
GMT+8, 2025-12-14 11:22 , Processed in 0.027193 second(s), 9 queries , Gzip On, Redis On.
