查看: 2772|回复: 2
[原创] need help to start an Asic project
发表于 2016-5-6 20:16:04 | 显示全部楼层 |阅读模式
Hi, everyone.
I am a newbie in FPGA and ASIC. I just started a project about implement openMSP430 in ASIC a few weeks ago but it is very difficult for me to start. Now I am trying to learn ASIC design flow and synthesis some small project. Anyone can give me an advice
发表于 2016-5-6 21:59:05 | 显示全部楼层
回复 1# khanhlinh
  Some suggestion that might help you.
1. You have to familiar verilog HDL firstly if you are not yet.
2. MSP430, is that a MCU ? If that, you may also need to study the micro processor architecture and instruction.
3. If you have design compiler, please read the user guide and try to do some example for synthesis and check timing/resource report. Study how to set library, timing parameter, and simple TCL command.
4. If you also want to do some FPGA jobs. You may need to study ISE/QuatusII software...
Too much to learn. Not easy.
 楼主| 发表于 2019-11-25 16:28:10 | 显示全部楼层
很久时间我没登录这个网站了。
真谢些你了
GMT+8, 2025-12-17 00:14 , Processed in 0.021699 second(s), 6 queries , Gzip On, Redis On.
