查看: 3731|回复: 2
[求助] vcs initreg
发表于 2022-3-4 19:29:22 | 显示全部楼层 |阅读模式
vcs 使用initreg 初始化,reg初始化为0  但是mem 还是XS。 请问这个怎么解决
发表于 2022-3-5 17:56:02 | 显示全部楼层
Initializing Memories and Regs
VCS has compile-time options for initializing all bits of memories and regs to the 0, 1, X, or Z value:
+vcs+initmem+0|1|x|z
Initializes all bits of all memories in the design.
+vcs+initreg+0|1|x|z
Initializes all bits of all regs in the design.
The +vcs+initmem option initializes regular memories and multi-dimensional arrays of the reg data type with more than two dimensions, for example:
reg [7:0] mem [7:0][15:0];
The +vcs+initmem option does not initialize multi-dimensional arrays of any other data type.
The +vcs+initreg option does not initialize registers (variables) other than the reg data type.
When you use these options, to prevent race conditions, you should avoid the following :
•Assigning initial values to a regs in their declaration when the value assigned is not the same as the value specified with the +vcs+initreg option, for example:
reg [7:0] r1 8’b01010101;
•Assigning values to regs or memory elements at simulation time 0 when the value assigned is not the same as the value specified with the +vcs+initreg or +vcs+initmem option, for example:
initial
begin
mem[1][1]=8’b00000001;
 楼主| 发表于 2022-3-7 16:17:04 | 显示全部楼层
VCS has compile-time options for initializing all bits of memories an ...
加assign这个不太现实,因为分布的很散且很多,有什么好的方法吗
GMT+8, 2025-12-21 13:17 , Processed in 0.015350 second(s), 3 queries , Gzip On, Redis On.
