查看: 2478|回复: 3
[求助] 求大神来指导
发表于 2016-2-26 16:29:13 | 显示全部楼层 |阅读模式
fullchip  setup fix 有那些手段,除了useful skew  size_cell ,还有其他的办法吗?
发表于 2016-6-3 14:41:37 | 显示全部楼层
回复 1# 天天快乐49
fix timing的方法大概有以下几种:1. size_cell
2. userful skew
3. insert_buffer
4. move cell location.
5. logic remap, like change the buffer to two inverter cells, this is quite similar like 3, which both try to cut the long net into smaller piece or split the sink.
6. You might also want to use some clone cell skills.
The most import is you need to know you have have these violations, then choose correponding solution to fix the violation.
发表于 2016-6-5 00:37:37 | 显示全部楼层
fix large  transition
use  net delay  more  while  setup/hold  conflict
 楼主| 发表于 2016-6-6 10:42:02 | 显示全部楼层
谢谢    让我大开眼界
GMT+8, 2025-9-18 03:16 , Processed in 0.012243 second(s), 3 queries , Gzip On, Redis On.
