查看: 1902|回复: 0
[求助] ansys designer8 运行警告
发表于 2015-12-28 09:52:58 | 显示全部楼层 |阅读模式
悬赏10资产未解决
运行结果出现Port 'Port1' is referenced to infinity.  Results maybe appear non-passive.  Use caution when interpreting the results.
-parameter value(s) greater than 1 at 1 GHz!
-parameter value(s) greater than 1 at 2.25 GHz!
-parameter value(s) greater than 1 at 1.625 GHz!
-parameter value(s) greater than 1 at 1.3125 GHz! 等等
请问是什么意思,哪里的问题
GMT+8, 2025-9-13 06:37 , Processed in 0.013852 second(s), 6 queries , Gzip On, Redis On.
