查看: 2750|回复: 1
Hotfix_SPB16.50.055_wint_1of1
发表于 2014-5-19 20:30:44 | 显示全部楼层 |阅读模式
DATE: 04-31-2014   HOTFIX VERSION: 055
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1199256 ALLEGRO_EDITOR INTERACTIV       DFA bubble does not appear when moving a symbol to within another symbols dfa bounds on specific symbols
1218706 CONSTRAINT_MGR CONCEPT_HDL      NCC associations get deleted from FE CM
1255320 F2B            OTHER            16.5 Export Physical CM enable switch needs disabled
1256457 CONCEPT_HDL    CONSTRAINT_MGR   Extracting a XNet from CM crashes the tool
1257423 ALLEGRO_EDITOR ARTWORK          Create Artwork log message error
1259677 CONCEPT_HDL    CORE             hier_write -forcereset cause component prop change.
链接: http://pan.baidu.com/s/1o6JjQAY 密码: oiuv
发表于 2014-12-19 12:35:55 | 显示全部楼层
回复 1# suiwinder
   good!,楼主好人,谢谢了
GMT+8, 2025-12-24 22:24 , Processed in 0.140436 second(s), 5 queries , Gzip On, Redis On.
