查看: 2282|回复: 0
[招聘] 急招数字IC验证(高级)工程师
发表于 2016-2-18 10:02:43 | 显示全部楼层 |阅读模式
IC Verification Senior Engineer
Responsibilities:
1.Compose the verification plan according to the chip specification and customer's use cases;
2.Adopt the advanced verification methodologies to create the whole verification environment from scratch according to the requirements of specific IC;
3.Design Behavioral functional model and test-benches with C/System C, Verilog/System Verilog and script languages
4.Create, build and implement test cases with high degree of accuracy to verify Device Under Test
5.Work closely with concept architect and RTL designer to verify RTL design through extensive test-bench simulation for modular and top-level design to obtain very high percentage of functional and code coverage
6.Work closely with FPGA prototyping application and validation engineers to verify functional design
7.Coach the inexperienced engineers in the team
8.Secondary task may include design of digital logic with high-level description language (VHDL/Verilog)  from specification.
Requirements:
1.Master's/Bachelor's Degree in Electrical/Electronics or Computer Engineering.
2.5+ years IC verification experience on the complex ASIC/SOC
3.Experience with advanced verification methodologies(VMM, OVM, UVM, etc.) including functional coverage and constrained random testing
4.Good knowledge of C, SystemC, and at least one of script languages: Perl, Python, etc.
5.Expert knowledge of VHDL/Verilog HDL and CAD tools (Synopsys and/or Cadence)
6.Team-work spirit, and with a strong drive to excel
7.Able to work independently on a given assignment and work hard to finish on time
8.Good written and communication skills
9.Previous experience on data network communication IC is an added advantage
成都苏州两地均招聘
如有意向请与 付女士联系   电话:0512-62727225    邮箱:fu.wenyan@xel-tech.com
GMT+8, 2025-11-26 00:22 , Processed in 0.016224 second(s), 5 queries , Gzip On, Redis On.
