查看: 6814|回复: 8
[求助] cadence 仿真smic .18um工艺库中的变容mos管出现错误
发表于 2013-4-19 10:49:37 | 显示全部楼层 |阅读模式
cadence 仿真smic .18um工艺库中的变容mos管出现错误,请教各位大侠:我使用了smic18mm中的pvar18_ckt_rf然后添加了模型库:spectre/ms018_rfv1p1_spe.lib  tt和spectre/ms018_rfv1p1_spe.lib  res_tt然后仿真便出现如下提示:
Fatal error found by spectre during AHDL read-in.
FATAL :File ……spectre/res_rf.def' does not appear to be a valid Verilog—A file . In previous releases, 'def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this is a SpectreHDL file, you need to replace it with an equivalent Verilog—A file.
 楼主| 发表于 2013-4-19 15:05:02 | 显示全部楼层
怎么没有人呢?
 楼主| 发表于 2013-4-20 15:00:22 | 显示全部楼层
我自己解决了,呵呵。打扰了
发表于 2014-9-30 18:36:11 | 显示全部楼层
楼上怎么解决的?请教啊  还有我自己建了个工艺模型的话 那我该怎样添加进去呢?
发表于 2014-9-30 18:40:52 | 显示全部楼层
cadence详细教程(模拟电路)
cadence详细教程(模拟电路).pdf
2.12 MB, 下载次数: 159 , 下载积分: 资产 -2 信元, 下载支出 2 信元
cadence详细教程(模拟电路)
发表于 2014-12-4 18:23:22 | 显示全部楼层
回复 3# nnltshan
   怎没解决的?求教啊。
发表于 2021-8-3 16:12:06 | 显示全部楼层
感谢分享
发表于 2021-8-12 11:10:58 | 显示全部楼层
  怎没解决的?
发表于 2022-9-19 19:35:37 | 显示全部楼层
看看
GMT+8, 2025-12-28 05:48 , Processed in 0.190320 second(s), 7 queries , Gzip On, Redis On.
