查看: 5402|回复: 9
Sentaurus2013 under FC20
发表于 2014-3-21 02:13:37 | 显示全部楼层 |阅读模式
When I tend to open "Imgrd", the following words appear:
[root@jinshan ~]# lmgrd -c /home/alain/synopsys/11.6/admin/license/license.dat
2:13:31 (lmgrd) -----------------------------------------------
2:13:31 (lmgrd)   Please Note:
2:13:31 (lmgrd)
2:13:31 (lmgrd)   This log is intended for debug purposes only.
2:13:31 (lmgrd)   In order to capture accurate license
2:13:31 (lmgrd)   usage data into an organized repository,
2:13:31 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
2:13:31 (lmgrd)   software license administration  solution,
2:13:31 (lmgrd)   FLEXnet Manager, to  readily gain visibility
2:13:31 (lmgrd)   into license usage data and to create
2:13:31 (lmgrd)   insightful reports on critical information like
2:13:31 (lmgrd)   license availability and usage. FLEXnet Manager
2:13:31 (lmgrd)   can be fully automated to run these reports on
2:13:31 (lmgrd)   schedule and can be used to track license
2:13:31 (lmgrd)   servers and usage across a heterogeneous
2:13:31 (lmgrd)   network of servers including Windows NT, Linux
2:13:31 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
2:13:31 (lmgrd)   www.flexerasoftware.com for more details on how to
2:13:31 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
2:13:31 (lmgrd)   for your enterprise.
2:13:31 (lmgrd)
2:13:31 (lmgrd)
2:13:31 (lmgrd)
2:13:31 (lmgrd) The license server manager (lmgrd) running as root:
2:13:31 (lmgrd)     This is a potential security problem
2:13:31 (lmgrd)     and is not recommended.
[root@jinshan ~]#  2:13:31 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 x64_lsb) started on jinshan.shi (linux) (3/21/2014)
2:13:31 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
2:13:31 (lmgrd) US Patents 5,390,297 and 5,671,412.
2:13:31 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
2:13:31 (lmgrd) License file(s): /home/alain/synopsys/11.6/admin/license/license.dat
2:13:31 (lmgrd) lmgrd tcp-port 27000
2:13:31 (lmgrd) Starting vendor daemons ...
2:13:31 (lmgrd) Started snpslmd (internet tcp_port 47212 pid 4533)
2:13:31 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:31 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/21/2014 02:13:31 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:32 (lmgrd) snpslmd exited with status 0 signal = 17
2:13:32 (lmgrd) Since this is an unknown status, license server
2:13:32 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
2:13:32 (lmgrd) REStarted snpslmd (internet tcp_port 35093 pid 4620)
2:13:32 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:32 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/21/2014 02:13:32 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:32 (lmgrd) REStarted snpslmd (internet tcp_port 59305 pid 4708)
03/21/2014 02:13:33 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:33 (lmgrd) snpslmd exited with status 0 signal = 17
2:13:33 (lmgrd) Since this is an unknown status, license server
2:13:33 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
2:13:33 (lmgrd) REStarted snpslmd (internet tcp_port 49597 pid 4794)
2:13:33 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:33 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
2:13:33 (lmgrd) REStarted snpslmd (internet tcp_port 55698 pid 4880)
2:13:34 (lmgrd) snpslmd exited with status 0 signal = 17
2:13:34 (lmgrd) Since this is an unknown status, license server
2:13:34 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
2:13:34 (lmgrd) REStarted snpslmd (internet tcp_port 40313 pid 4966)
2:13:34 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:34 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/21/2014 02:13:34 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:34 (lmgrd) REStarted snpslmd (internet tcp_port 48025 pid 5052)
2:13:35 (lmgrd) snpslmd exited with status 0 signal = 17
2:13:35 (lmgrd) Since this is an unknown status, license server
2:13:35 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
2:13:35 (lmgrd) REStarted snpslmd (internet tcp_port 37286 pid 5138)
2:13:35 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:35 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/21/2014 02:13:35 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:35 (lmgrd) REStarted snpslmd (internet tcp_port 52135 pid 5224)
2:13:35 (lmgrd) REStarted snpslmd (internet tcp_port 51504 pid 5310)
03/21/2014 02:13:36 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.6
2:13:36 (lmgrd) snpslmd exited with status 0 signal = 17
2:13:36 (lmgrd) Since this is an unknown status, license server
2:13:36 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
2:13:36 (lmgrd) REStarted snpslmd (internet tcp_port 38902 pid 5396)
2:13:36 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
2:13:36 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
2:13:36 (lmgrd) Please correct problem and restart daemons
Who knows what the hell??? Thanks.
发表于 2014-3-21 13:23:38 | 显示全部楼层
 楼主| 发表于 2014-3-21 16:21:24 | 显示全部楼层
回复 2# zz1313
    可惜了,不是这个原因,我准备发个帖子。
 楼主| 发表于 2014-3-21 19:09:38 | 显示全部楼层
回复 4# 卖女孩的小火柴
但你难以想象什么问题
发表于 2014-3-21 19:28:52 | 显示全部楼层
换个用户试试。
发表于 2014-6-27 11:06:15 | 显示全部楼层
楼主有没有结果啊?我也遇到同样的问题!解决不了!
 楼主| 发表于 2014-6-27 12:42:55 | 显示全部楼层
回复 7# weishsu
   看我的帖子http://bbs.eetop.cn/thread-440142-1-1.html
发表于 2014-8-17 02:36:42 | 显示全部楼层
找到需要的东西了,谢谢!
发表于 2014-10-9 19:34:39 | 显示全部楼层
发表于 2016-5-26 14:58:36 | 显示全部楼层
thanks for sharing
GMT+8, 2025-12-24 22:33 , Processed in 2.756638 second(s), 5 queries , Gzip On, Redis On.
