查看: 3741|回复: 3
[讨论] Tetramax atpg simulation problem help
发表于 2011-4-6 20:46:04 | 显示全部楼层 |阅读模式
Hi friend,
when I simulate the ATPG files in modelsim,appear problem as follows:
# //            0.00 ns : Begin test_setup
# //          200.00 ns : Begin patterns, first pattern = 0
# //          200.00 ns : ...begin scan load for pattern 0
# // *** ERROR during scan pattern 0 (detected during load of pattern 1)
#   0 chain1 1 (exp=0, got=1)  // pin P3[0], scan cell 1, T=       37440.00 ns
#   0 chain4 1 (exp=0, got=1)  // pin P3[3], scan cell 1, T=       37440.00 ns
#   0 chain1 3 (exp=1, got=0)  // pin P3[0], scan cell 3, T=       37640.00 ns
#   0 chain4 3 (exp=1, got=0)  // pin P3[3], scan cell 3, T=       37640.00 ns
#   0 chain1 5 (exp=0, got=1)  // pin P3[0], scan cell 5, T=       37840.00 ns
#   0 chain4 5 (exp=0, got=1)  // pin P3[3], scan cell 5, T=       37840.00 ns
#   0 chain1 7 (exp=1, got=0)  // pin P3[0], scan cell 7, T=       38040.00 ns
#   0 chain4 7 (exp=1, got=0)  // pin P3[3], scan cell 7, T=       38040.00 ns
#   0 chain1 9 (exp=0, got=1)  // pin P3[0], scan cell 9, T=       38240.00 ns
#   0 chain4 9 (exp=0, got=1)  // pin P3[3], scan cell 9, T=       38240.00 ns
#   0 chain1 11 (exp=1, got=0)  // pin P3[0], scan cell 11, T=       38440.00 ns
#   0 chain4 11 (exp=1, got=0)  // pin P3[3], scan cell 11, T=       38440.00 ns
#   0 chain1 13 (exp=0, got=1)  // pin P3[0], scan cell 13, T=       38640.00 ns
#   0 chain4 365 (exp=0, got=1)  // pin P3[3], scan cell 365, T=       73840.00 ns
#   0 chain1 366 (exp=1, got=0)  // pin P3[0], scan cell 366, T=       73940.00 ns
#   0 chain4 366 (exp=1, got=0)  // pin P3[3], scan cell 366, T=       73940.00 ns
#        74000.00 ns --BUS CONFLICT-- : AAA_tmax_testbench_1_16.dut.io_pad_inst.P34_PAD
#        74000.00 ns --BUS CONFLICT-- : AAA_tmax_testbench_1_16.dut.io_pad_inst.P30_PAD
# // *** ERROR during scan pattern 1 (detected during load of pattern 2)
#   1 chain1 0 (exp=0, got=1)  // pin P3[0], scan cell 0, T=       74440.00 ns
#   1 chain4 0 (exp=0, got=1)  // pin P3[3], scan cell 0, T=       74440.00 ns
#   1 chain1 1 (exp=1, got=0)  // pin P3[0], scan cell 1, T=       74540.00 ns
#   1 chain4 1 (exp=1, got=0)  // pin P3[3], scan cell 1, T=       74540.00 ns
#   1 chain4 2 (exp=0, got=1)  // pin P3[3], scan cell 2, T=       74640.00 ns
#   1 chain1 3 (exp=0, got=1)  // pin P3[0], scan cell 3, T=       74740.00 ns
#   1 chain4 3 (exp=1, got=0)  // pin P3[3], scan cell 3, T=       74740.00 ns
#   1 chain1 4 (exp=1, got=0)  // pin P3[0], scan cell 4, T=       74840.00 ns
what is the reason that cause "exp=1, got=0" or  "exp=0, got=1"?
is it need to add the .sdf to the simulation project??
I am confuse about it.Expect your answer..
thanks
Best regards!!
发表于 2011-4-13 14:30:53 | 显示全部楼层
是需要加上sdf的
exp=1, got=0" or  "exp=0, got=1 是有错误出现了,你可以看一下仿真波形看为什么希望是1的时候出现了0,看你的问题估计是哪里没有设对,不是timing的问题,要不然不会出现这么多错误的!
发表于 2019-12-23 11:20:26 | 显示全部楼层
mark。 我也遇到这个问题了, 综合后网表能过,但是用后端返回的网表跑simulation也是和楼主一样,一大堆的错。不知道怎么debug。我的设置和以前的项目一样,这次不知道为啥不行了。
发表于 2019-12-23 17:46:35 | 显示全部楼层
rencj1979 发表于 2011-4-13 14:30
是需要加上sdf的
exp=1, got=0" or  "exp=0, got=1 是有错误出现了,你可以看一下仿真波形看为什么希望是1 ...
已解决。
因为没有加sdf跑,所以错了。
GMT+8, 2025-12-18 07:07 , Processed in 0.018314 second(s), 6 queries , Gzip On, Redis On.
