查看: 4652|回复: 3
[求助] innovus design import问题
发表于 2016-9-3 11:51:07 | 显示全部楼层 |阅读模式
我在使用oa 方式import 窗口界面报的error:Base constraint group name “LEFDefaultRouteSpec” for reading all the rules is not found .
Provide one or change the base constraint group using “set_init_oa_default_rule name and read the OA database again.
ERROR:Fail to read LEF information from OA reference librarys. check the OA database and your input
不明白具体错误是什么 reference lib 是用 lef2oa 这个命令得来的
发表于 2017-6-1 01:11:23 | 显示全部楼层
U got more information, please
发表于 2018-5-5 15:43:11 | 显示全部楼层
是的,refence lib可以从lef2oa转出来
发表于 2019-2-26 11:44:52 | 显示全部楼层
GMT+8, 2025-12-21 01:30 , Processed in 0.057087 second(s), 6 queries , Gzip On, Redis On.
