查看: 4186|回复: 1
[求助] linux6.5+MMSIM10+IUS9.2,仿真AMS中的APS错误。
发表于 2016-8-18 17:19:25 | 显示全部楼层 |阅读模式
Warning from spectre in `cds_globals', during circuit read-in.
    `cds_globals': Parameter `k' redefines parameter of same name defined at
        higher level.
    `cds_globals': Parameter `f' redefines parameter of same name defined at
        higher level.
Opening directory amsControlAPS.ahdlSimDB/ (775)
Compiling ahdlcmi module library.
Error found by spectre during AHDL read-in.
    Cannot compile ahdlcmi module library. Check the log file
        amsControlAPS.ahdlSimDB/bsource_1.amsControlAPS.ahdlcmi/Linux2.6.32-431.el6.x86_64+gcc/
        for details. If the compiler ran out of memory, use 'setenv
        CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was
        a syntax error, contact your Cadence Customer Support representative
        with the netlist, log files, behavioral model files, and any other
        information that can help identify the problem.
Warning from spectre in `mom_2t_ckt':`test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx',
        in
        `PDL360+PDL_SHIFT360+av_extracted+0x10000001':`test_PDL_SHIFT360.I34',
        in `PDL360+test_PDL_SHIFT360+schematic+0x10000001':`test_PDL_SHIFT360',
        during hierarchy flattening.
    "/home/xlq/cadence/pdk/smic55llrf_1tm_9k_cds_1P8M_2012_7_17_v1.3/smic55llrf/../models/spectre/l0055ll_v1p3_1r_mom_spe.ckt"
        48: test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx.cab: `temp' is not a valid
        parameter for an instance of `bsource_1'.  Ignored.
        48: test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx.cab: `tnom' is not a valid
        48: test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx.cab: `bs_par_0' is not a
        valid parameter for an instance of `bsource_1'.  Ignored.
        48: test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx.cab: `bs_par_1' is not a
        48: test_PDL_SHIFT360.I34.Xxi2|xc0_1__rcx.cab: `bs_par_2' is not a
        Further occurrences of this warning will be suppressed.
spectre terminated prematurely due to fatal error.
ncsim: *E,RNALER: Simulation terminated due to analog error.
Memory Usage - 17.7M program + 768.4M data = 786.2M total
CPU Usage - 0.1s system + 2.9s user = 3.0s total (63.9% cpu)
ncsim> exit
ncsim: Memory Usage - 17.7M program + 768.4M data = 786.1M total
ncsim: CPU Usage - 0.1s system + 3.2s user = 3.3s total (5.1s, 64.9% cpu)
TOOL:
ncsim
09.20-s018: Exiting on Aug 18, 2016 at 16:51:06 CST  (total: 00:00:05)
错误如上,本人怀疑是由于新更新的电脑装的linux6.5的64位系统,ius92太旧,是否有解决方法
发表于 2021-1-5 15:14:46 | 显示全部楼层
楼主,解决了吗?
GMT+8, 2025-12-19 13:51 , Processed in 0.017674 second(s), 6 queries , Gzip On, Redis On.
