查看: 3485|回复: 2
[求助] microblaze
发表于 2015-11-16 21:17:04 | 显示全部楼层 |阅读模式
我的板子是virtex6 ml605,在调试microblaze中reset信号设置为高电平有效,但一直报错ERROR: MicroBlaze is under RESET. Check if the Reset input to MicroBlaze and its Bus Interfaces are connected properly
发表于 2017-11-23 17:34:44 | 显示全部楼层
是不是复位极性设置的不对
发表于 2017-11-24 10:50:07 | 显示全部楼层
its Bus Interfaces are connected properly?
再检查检查
GMT+8, 2025-12-27 13:14 , Processed in 0.014767 second(s), 6 queries , Gzip On, Redis On.
