查看: 2093|回复: 3
[求助] ISE 扩频?
发表于 2015-6-30 15:14:37 | 显示全部楼层 |阅读模式
这是我们的一个课程作业,我不学这个方向,马上要交了。。。但是IP核都没更新完,希望大神能给解释下这部分代码啊。这个是程序的链接。希望能有大神给看下http://pan.baidu.com/s/1i36ad3Ralways @(posedge clk)
begin
if (en == 1 && en_ram_send)
  begin
    if(dspdatacon == 1)
   begin
  if(send_counter[19:13]<96 && send_frame_once == 0)
     begin
    addr[6:0] <= send_counter[19:13];
frame_head <= 1;
  end
  else
  begin
frame_head <= 0;
send_frame_once <= 1;//已发送
  end
end
    else if(clr || ((dspdatacon || frame_data_96)==0))
       send_frame_once <= 0;
  end
begin
end
end
begin
begin
send_counter <= 0;
end
else if (en == 1)
begin
pn_adr <= send_counter[12:3];
if(dspdatacon == 1)
   wea <= 1;
else
   wea <= 0;
if(send_counter[2:0] == 3'b111)
en_8 <= 1;
else
en_8 <= 0;
if(send_counter[12:0] == 13'b0111111110111)
clk_wuma <= ~clk_wuma;//信号翻转
if(send_counter[12:0] == 13'b1111111110111)
begin
en_127_8 <= 1;
send_counter[12:0] <= 0;
send_counter[19:13] <= send_counter[19:13] + 1;
   if(frame_head == 0 && frame_data_96 == 1)
    begin
  addrb_data_read <= addrb_data_read + 1;
  end
   else
  addrb_data_read <= 0;
if(dspdatacon == 1)
  begin
    frame_data_96 <= 1;
addr_write <= addr_write + 1 ;
wait_once <= 1'b0;
counter_wait_96<= 0;
  end
   else begin
  addr_write <= 0 ;
  if(counter_wait_96 < 96 && wait_once ==0 && frame_data_96==1)
    counter_wait_96 <= counter_wait_96 + 1;
  else begin
counter_wait_96 <= 0;
wait_once <= 1;
frame_data_96 <= 0;
        end
      end
       end
    else
  begin
send_counter[12:0] <= send_counter[12:0] + 1;
en_127_8 <= 0;
  end
end
else begin
en_8 <= 0;
en_127_8 <= 0;
end
end
begin
if(clr) begin
  rcosflt_in <= 0;
end
else if(en_8 == 1)begin
  begin
      if((dspdatacon || frame_data_96) == 1)
begin
spectrum_data_out <= inp_dif ^ pncode;
case (spectrum_data_out)
1'b0  : begin
                  rcosflt_in <=2'b01;
               end
1'b1  : begin
                  rcosflt_in <= 2'b11;
               end
endcase
end
else
rcosflt_in <= 2'b00;
  end
end
end
begin
if(clr) begin
inp_dif <= 0;
end
else if(en_127_8 == 1)begin
      if(frame_head ==1 )
begin
  inp_dif <= send_framehead ^ inp_dif;
end
      else
begin
     inp_dif <= data_ram_out ^ inp_dif;
end
out_impulse_inp <= impulse_inp;
end
end
endmodule
发表于 2015-6-30 20:29:34 | 显示全部楼层
没人看得懂你这个
 楼主| 发表于 2015-7-1 13:14:48 | 显示全部楼层
回复 2# killyliu
   额。不好意思,这一块很多,我不知道应该怎么附。。。
发表于 2015-7-1 20:55:25 | 显示全部楼层
你没有前后文,呵呵呵。。。。。。。。。。
GMT+8, 2025-12-26 01:34 , Processed in 0.022805 second(s), 8 queries , Gzip On, Redis On.
