查看: 1934|回复: 0
[求助] CTS的问题
发表于 2014-4-23 18:51:05 | 显示全部楼层 |阅读模式
在place之后,做CTS时,check_clock_tree之后,报出了如下的warning,man 了一下,没有太理解,路过的大神求解~~~
Warning: The clock 'EMIF_clk' defined at port 'EMIF_clk_o_pad' loops to itself. (CTS-832)
  0:  EMIF_clk_o_pad
  1:  EMIF_clk_o_pad
Warning: The clock 'clk_o_fpa' defined at port 'clk_fpa_10' loops to itself. (CTS-832)
  0:  clk_fpa_10
  1:  clk_fpa_10
Warning: The clock 'clk_o_led' defined at port 'clk_o_10' loops to itself. (CTS-832)
  0:  clk_o_10
  1:  clk_o_10Warning: The clock 'EMIF_clk' defined at port 'EMIF_clk_o_pad' loops to itself. (CTS-832)
  0:  EMIF_clk_o_pad
  1:  EMIF_clk_o_pad
  0:  clk_fpa_10
  1:  clk_fpa_10
  0:  clk_o_10
  1:  clk_o_1
上面的port都是输出端口的port,定义在端口的时钟是第三个输出时钟,报出这个问题后,下面好像是要定义set_clock_tree_exception,但是怎么定义呢???
GMT+8, 2025-12-24 08:49 , Processed in 0.012745 second(s), 5 queries , Gzip On, Redis On.
