查看: 20450|回复: 7
silvaco2016安装sflm的验证问题
发表于 2016-10-25 15:07:11 | 显示全部楼层 |阅读模式
各位大神,我是参照的http://bbs.eetop.cn/thread-402000-1-1.html 这篇帖子安装的,系统是CentOS6.7具体问题像下面
[root@oeic bin]# /usr/tools/silvaco2016/bin/sflm -i
************ W A R N I N G ************
You do not seem to be running a
supported release of Linux. (CentOS)
find: `/root/.silvaco': No such file or directory
sh: /root/.silvaco/sysname.warning: No such file or directory
sysname warning: Unsupport linux version. (CentOS)
Version of rpc.sflmserverd : ************ W A R N I N G ************
8.2.12.R
Version of sflm_monitord : ************ W A R N I N G ************
7.4.16.R
License file /var/opt/sflm/licenses/Silvaco_56143.1.lic :
    LICENSE_ID Silvaco_56143.1  VERSION 5  KEY abWdghgT5.
Setting SFLM administrative password.
New Password    ?
aksusbd version   1.14 (#7528) - key API (USB) version: 3.88
aksusbd version         - (parallel driver not available)
Running s_install version: 2.0.3.R  please wait...
Terminating SFLM RPC servers ... done.
Currently 37108448 KB free in /tmp (>= 8000)
Preparing to install the SFLM server daemon.
This procedure will modify or create the following system files:
        /etc/rc.d/init.d/sflm
Backups will be created in /var/tmp/s_install.bak
before any files are modified.
Run '/usr/tools/silvaco2016/etc/s_install -rm-bak' or
'/var/tmp/s_install.bak/remove' to remove backup files.
Do you wish to proceed? [y|n] y
Verifying permissions ... done.
Installing servers in init.d ...
Backing up /etc/rc.d/init.d/sflm to /var/tmp/s_install.bak/bak.sflm~1~ ... done.
Installation done.
Starting and verifying servers ...
SFLM using license file: /var/opt/sflm/licenses
SFLM server ready.
rpcinfo: oeic: Name or service not known
Verification failed for sflm on host oeic.
RPC server verification failed.
发表于 2016-12-6 09:36:07 | 显示全部楼层
The same situation with you.
发表于 2016-12-20 09:44:02 | 显示全部楼层
有破解的licesen和rpc程序吗?
发表于 2017-9-3 22:11:06 | 显示全部楼层
你把license文件里的时间改一下,如下面红色字体的部分。我改了之后就行了。
#v "SFLM License File"
# silvaco.file ASCII version=1.8.27 format=1
VERSION 5
GENERATED "Sun, 1 Jan 2015 17:27:18 GMT"
VENDOR Silvaco
LICENSE_ID Silvaco_2016
MAINTENANCE_DATE "Mon, 14 Nov 2080 08:00:00 GMT"
#LICENSE_STATUS Evaluation
LM_HOSTIDS localhost.localdomain-6e7ea7bc-80c850b7
NL_HOSTIDS
START_DATE "Sun, 1 Jan 2015 08:00:00 GMT"
END_DATE "Mon, 14 Nov 2080 08:00:00 GMT"
# Floating Products
USERS 999
发表于 2018-2-23 13:31:14 | 显示全部楼层
不管這訊息 ~~  好像也是可以運作的。
发表于 2020-10-10 01:00:56 | 显示全部楼层
thanks
发表于 2023-7-28 12:29:14 | 显示全部楼层
感谢分享
发表于 2023-7-28 12:31:56 | 显示全部楼层
厉害
回复 支持 0 反对 1
GMT+8, 2025-12-24 11:12 , Processed in 0.022627 second(s), 5 queries , Gzip On, Redis On.
