查看: 3068|回复: 4
[求助] 路径延迟问题
发表于 2013-9-4 16:21:32 | 显示全部楼层 |阅读模式
在设计中碰到了这么三个错误:
三个相似,其中slack最大的如下:
Timing constraint: TS_u_clk_gen_gclk2_bufg = PERIOD TIMEGRP "u_clk_gen_gclk2_bufg" TS_CLK_200MHz_p * 0.625 HIGH 50%;
For more information, see Period Analysis in the Timing Closure User Guide (UG612).
  13506306 paths analyzed, 1974 endpoints analyzed, 31 failing endpoints
  31 timing errors detected. (31 setup errors, 0 hold errors, 0 component switching limit errors)
  Minimum period is   8.816ns.
Paths for end point u_ethernet/u_frame_gen/ip_head_data_77 (SLICE_X11Y30.C3), 297000 paths
Slack (setup path):     -0.816ns (requirement - (data path - clock path skew + uncertainty))
   Source:               u_ethernet/u_frame_gen/ipIdentifier_r_3 (FF)
   Destination:          u_ethernet/u_frame_gen/ip_head_data_77 (FF)
   Requirement:          8.000ns
   Data Path Delay:      8.682ns (Levels of Logic = 13)
   Clock Path Skew:      -0.002ns (0.243 - 0.245)
   Source Clock:         clk_125MHz rising at 0.000ns
   Destination Clock:    clk_125MHz rising at 8.000ns
   Clock Uncertainty:    0.132ns
   Clock Uncertainty:          0.132ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
     Total System Jitter (TSJ):  0.070ns
     Discrete Jitter (DJ):       0.254ns
     Phase Error (PE):           0.000ns
通过我的分析,我认为,源寄存器ipIdentifiter_r[3]--> 目的寄存器ip_head_data[77],路径延迟为8.682ns,加上建立时间等,总共8.816ns,这都超过了系统时钟8.00ns的要求。 以至于报错!
情况如下:仿真如下图:
仿真图
仿真图
tframe_end是在每发送一帧后使能标志帧结束。部分代码如下:
reg [15:0] rxIpTotalLen_r;
always @(posedge clkin)
  if(reset_n==1'b0)
    ipIdentifier_r <= `UD 16'd1;
  else if(tframe_end==1'b1)
    ipIdentifier_r <= `UD ipIdentifier_r + 1;
assign Identifier  = ipIdentifier_r;
wire [159:0] ip_head_data_w1;
assign ip_head_data_w1 = {Version[3:0],HeadLen[3:0],ServiceType[7:0],TotalLen[15:0],
                          Identifier[15:0],Flags[2:0],FragOffset[12:0],
                          TimeToLive[7:0],Protocol[7:0],IpHeadChecksum[15:0],
                          cap_ip[31:0],pc_ip[31:0]};
    if(head_flag==1'b1) begin
         if(cnt_base[3]==1)
              ip_head_data[159:0] <= `UD ip_head_data_w1;
          end
     else begin
        ip_head_data[159:8] <=`UD ip_head_data[151:0];
        ip_head_data[7:0]   <= `UD 8'h00;
     end
ipIdentifiter_r 是在每发一帧结束后,自己累加1.而到达目的寄存器ip_head_data是在帧格式打包的中部组帧, 以至于相当于中间应该有很多节点,而这段时间远远超过1个时钟的周期,为什么这里还报错呢?请教各位,有什么建议,可以说一下,先谢谢了,
发表于 2013-9-4 16:41:03 | 显示全部楼层
如果数据经过多个周期才使用,可以设置成多周期的约束。
发表于 2013-9-5 14:33:19 | 显示全部楼层
贴的代码看不出什么东东
发表于 2013-9-6 22:42:32 | 显示全部楼层
看的太累,打几拍吧
发表于 2013-9-9 10:21:11 | 显示全部楼层
如果正如你所想的 数据的重组需要大于一个周期 那你就设置多周期路径,不然你优化一下在数据中间多打几拍
GMT+8, 2025-12-25 06:09 , Processed in 0.022170 second(s), 7 queries , Gzip On, Redis On.
