查看: 3257|回复: 3
[求助] 布局布线问题
发表于 2013-7-28 18:32:09 | 显示全部楼层 |阅读模式
WARNINGlace:916 - Local congestion has been detected on component
   uu12/outclk69. There is a limitation that at most 2 global signals can drive
   non-clock pins per CLB. The placer has detected that component uu12/outclk69
   has 3 non-clock pins driven by global signals. Placement will continue but
   note that this situation may lead to an unroutable situation.
请问这个问题该如何解决?
发表于 2013-7-29 13:40:56 | 显示全部楼层
component uu12/outclk69中有三个非时钟管脚有全局信号驱动,理论上最多只能有两个,去掉一个就完了。你看不懂吗?
发表于 2013-8-26 14:18:58 | 显示全部楼层
回复 2# chen851112
    很久没见您发言了,看到我的求助,空看啊!!!
 楼主| 发表于 2014-3-19 19:50:10 | 显示全部楼层
回复 2# chen851112
你好,谢谢您的关注,方便留个联系方式吗,我想详细咨询一下,我的qq1059211824
GMT+8, 2025-12-24 16:29 , Processed in 0.026215 second(s), 8 queries , Gzip On, Redis On.
