查看: 3325|回复: 0
[求助] 一个用ModelSim仿真lpm_ff的问题
发表于 2013-7-21 00:21:46 | 显示全部楼层 |阅读模式
我是一个FPGA初学者,刚刚接触用Modelsim-Altera 仿真。今天用一个例化的lpm_ff做练习,可是出现了问题。我编写的verilog 代码很简单,如下:
module FDDF(clk,clear,q);
input clk,
clear;
output q;
lpm_ff f1(.enable(1'b1),.clock(clk),.sclr(1'b0),.data(cle ar),.q(q));
defparam f1.LPM_WIDTH=1,
f1.LPM_FFTYPE = "DFF";
endmodule
然后是testbench 代码
`timescale 1 ps/ 1 ps
module FDDF_vlg_tst();
// constants
// general purpose registers
reg eachvec;
// test vector input registers
reg clear;
reg clk;
// wires
wire q;
// assign statements (if any)
FDDF i1 (
// port map - connection between master ports and signals/registers
.clear(clear),
.clk(clk),
.q(q)
initial
begin
// code that executes only once
// insert code here --> begin
clk=0;
clear=0;
// --> end
$display("Running testbench");
end
always #25 clk = ~clk ;
endmodule
// constants
reg eachvec;
reg clear;
reg clk;
// wires
wire q;
FDDF i1 (
.clear(clear),
.clk(clk),
.q(q)
initial
begin
clk=0;
clear=0;
// --> end
end
endmodule
编译都通过了,但用ModelSim-Altera 仿真的时候,报错了
错误代码是:Error: (vsim-10000) C:/Users/Tei.YLIB_TEI-PC/Desktop/DFF3/FDDF.v(10): Unresolved defparam reference to 'LPM_WIDTH' in f1.LPM_WIDTH.
Error: (vsim-10000) C:/Users/Tei.YLIB_TEI-PC/Desktop/DFF3/FDDF.v(11): Unresolved defparam reference to 'LPM_FFTYPE' in f1.LPM_FFTYPE.
我明明在代码里设定好了触发器的参数,但不知道为什么会报错。
各位高手谁能帮忙解答下,万分感激!
GMT+8, 2025-12-28 15:39 , Processed in 0.016091 second(s), 7 queries , Gzip On, Redis On.
