查看: 2212|回复: 2
[求助] virtual flat placement该如何翻译?这个名字反映了该步骤的什么特点?
发表于 2013-5-31 16:50:48 | 显示全部楼层 |阅读模式
为什么是virtual?为什么是flat?名字反映了virtual flat placement的什么特点?
刚开始看书,有很多地方不是很了解。请大侠指导菜鸟。感激不尽。
发表于 2013-6-1 09:29:45 | 显示全部楼层
估计是floorplan/partition时用的
工具在内部把netlist打平,做一个placement
发表于 2014-4-20 20:27:59 | 显示全部楼层
Virtual flat placement is the simultaneous placement of standard cells and macros for the whole chip
This placement is “virtual” because it temporarily considers the design to be entirely flat, without hierarchy. After you decide on the shapes and locations of the physical blocks, you restore the design hierarchy and proceed with the block-by-block physical design flow.
GMT+8, 2025-12-20 02:37 , Processed in 0.025006 second(s), 5 queries , Gzip On, Redis On.
