查看: 2749|回复: 1
[求助] ICC经常会出现flat,和hierarchical
发表于 2014-10-23 10:32:42 | 显示全部楼层 |阅读模式
例如all_fanout -flat
Specifies to function in the flat mode of  operation.   The  two
              major  modes  in  which  all_fanout  functions  are hierarchical
              (default) and flat.  When in  hierarchical  mode,  only  objects
              from  the  same  hierarchy  level  as  the  current  source  are
              returned.  Thus, pins within a level  of  hierarchy  lower  than
              that  of the source are used for traversal but are not reported.
          看的云里雾里的,新人求解释
发表于 2014-10-23 11:33:39 | 显示全部楼层
指的是 -flat 可 trace print 穿越所有 Hirearchy level Leaf cell pin, default 是在同一個 level 的 leaf cell pin 才被 print 出來.
GMT+8, 2025-12-25 15:00 , Processed in 0.014748 second(s), 7 queries , Gzip On, Redis On.
