查看: 1771|回复: 0
[求助] 时钟约束
发表于 2012-12-7 20:05:45 | 显示全部楼层 |阅读模式
Derived Constraints for u1/u3/u1/U7/clk_s1
|                               |   Period    |       Actual Period       |      Timing Errors        |      Paths Analyzed       |
|           Constraint          | Requirement |-------------+-------------|-------------+-------------|-------------+-------------|
|                               |             |   Direct    | Derivative  |   Direct    | Derivative  |   Direct    | Derivative  |
|u1/u3/u1/U7/clk_s1             |  20752.075ns|      2.075ns|  39553.455ns|            0|           67|           15|       240301|
| u1/u3/u1/U7/p2/CLK180_BUF     |  20752.075ns|  39553.455ns|          N/A|           67|            0|        50509|            0|
| u1/u3/u1/U7/p2/CLK2X_BUF      |  10376.038ns|      9.107ns|          N/A|            0|            0|       189767|            0|
| u1/u3/u1/U7/clk90             |  20752.075ns|      2.245ns|      9.024ns|            0|            0|           15|           10|
|  u1/u3/u1/U7/p3/CLK2X_BUF     |  10376.038ns|      4.512ns|          N/A|            0|            0|           10|            0|
1 constraint not met.
INFO:Timing:2761 - N/A entries in the Constraints list may indicate that the
   constraint does not cover any paths or that it has no requested value.
clk_s1是第一个dcm的clkfx_out输出的时钟,clk_s1是作为第二个DCM的时钟输入,求指教呀
GMT+8, 2025-12-25 22:51 , Processed in 0.018659 second(s), 6 queries , Gzip On, Redis On.
