查看: 3941|回复: 5
[求助] insert_pad_filler出现问题
发表于 2012-11-29 19:40:28 | 显示全部楼层 |阅读模式
RT
用ICC布局布线,在insert_pad_filler时,提示了下面的warning,导致creat pad ring失败。请问各位大大,这是怎么回事!怎么解决?搞了很久了,还没搞定!
WARNING : Cannot find filler cells for gap (240000 0) (295855 0)
WARNING : Cannot find filler cells for gap (335855 0) (391710 0)
WARNING : Cannot find filler cells for gap (431710 0) (487565 0)
WARNING : Cannot find filler cells for gap (527565 0) (583420 0)
WARNING : Cannot find filler cells for gap (623420 0) (679275 0)
WARNING : Cannot find filler cells for gap (719275 0) (775130 0)
WARNING : Cannot find filler cells for gap (815130 0) (870985 0)
WARNING : Cannot find filler cells for gap (910985 0) (966840 0)
发表于 2012-11-29 23:21:24 | 显示全部楼层
remove_placement_blockage -all
然后再来,
 楼主| 发表于 2012-11-30 10:14:57 | 显示全部楼层
回复 2# icfbicfb
    试了,还是没用!
发表于 2012-11-30 13:33:37 | 显示全部楼层
那些位置间隙小于最小的filler,可以设置overlap最小filler
 楼主| 发表于 2012-11-30 16:34:04 | 显示全部楼层
回复 4# zhouchong0904
    用什么命令呢?
发表于 2019-9-4 16:56:24 | 显示全部楼层
insert_pad_filler -cell "smallest_pad_filler_name" -overlap_cell "smallest_pad_filler_name"
GMT+8, 2025-12-24 22:16 , Processed in 0.023112 second(s), 6 queries , Gzip On, Redis On.
