查看: 9344|回复: 2
[求助] Verilog 中浮点数的表示方法 求大侠指导 $rtoi $bitstoreal 转化后的格式
发表于 2012-11-27 11:42:12 | 显示全部楼层 |阅读模式
input   [63:0] Input_rsvd;  // double
real               Input_rsvd_1;  // double
wire signed [19:0] ConvertIn_out1;  // sfix20_En19
always @* Input_rsvd_1 <= $bitstoreal(Input_rsvd);
assign ConvertIn_out1 = $rtoi(Input_rsvd_1 * (2**19));
请问上面代码中ConvertIn_out1最后的格式是怎样的?
发表于 2012-11-27 15:29:51 | 显示全部楼层
帮顶了
发表于 2017-5-12 10:48:38 | 显示全部楼层
Conversion Functions
Formal Definition
Conversion functions convert data formats between integer, real and bit representations.
Simplified Syntax
$bitstoreal(bit_number) ;
$itor(integer_number) ;
$realtobits(real_number) ;
$rtoi(real_number) ;
Description
The $bitstoreal function converts a bit pattern to a real number. The $itor function converts an integer to a real number. The $realtobits function converts a real number to its binary a equivalent. The $rtoi function converts a real number to an integer.
Examples
Example 1
reg [31:0] a, result_b ;
integer b, result_I ;
real c, result_r ;
result_r = $bitstoreal(a) ;
result_r = $itor(b) ;
result_b = $realtobits(c) ;
result_I = $rtoi(c) ;
Important Notes
Conversion functions are not synthesizable.
GMT+8, 2025-12-23 08:40 , Processed in 0.047347 second(s), 5 queries , Gzip On, Redis On.
