查看: 10191|回复: 2
[讨论] SPEF and SDF(reprint)
发表于 2012-11-19 14:21:08 | 显示全部楼层 |阅读模式
SPEF file describes spice netlist and RC infromation.
After running LVS(LVS correctly), you can generate SPEF file from RC extraction tool(Xcalibre,Calibre-XRC--Mentor
Star-RCXT--synopsys) or APR tool.
As for SDF file, it describes cell delay(from synthesis library) and interconnect delay(from SPEF file).
You can generate it from APR tool and PrimeTime(STA analysis tool).
If you want to get accuracy SDF file to do STA analysis.
I recommend you can use rc extraction tool to generate SPEF file and load into PrimeTime to generate SDF file to do
STA analysis.
SDF consists cell delays & interconnect delays. at synthesis level this file is used for timing analysis. that
interconnect delays are only an estimation. its not the real & exact interconnect delays. after compleate place &
route only we can get the exact interconnect delays.
after P&R, parasitic & interconnect delays are extracted using tools, that info is SPEF file. this file will be
fedback to static timing analysis tools to do timing analysis on filnal p&r netlist.
发表于 2012-11-19 15:09:42 | 显示全部楼层
什么意思?没头没脑的
发表于 2012-11-19 19:03:03 | 显示全部楼层
WAITING
GMT+8, 2025-12-21 17:21 , Processed in 0.017106 second(s), 6 queries , Gzip On, Redis On.
