查看: 8896|回复: 13
[求助] 请教ICC中关于Timing Analasis的几个命令[已解决]
发表于 2012-11-13 16:49:44 | 显示全部楼层 |阅读模式
(1) set timing_enable_multiple_clocks_per_reg true
(2) set case_analysis_with_logic_constants true
(3) set_fix_multiple_port_nets -all -buffer_constants
请问这三条命令是什么意思啊?谢谢!
发表于 2012-11-13 17:01:32 | 显示全部楼层
(1) 允许有多个时钟触发寄存器(比如两个时钟经多选器后驱动寄存器)
(2) 使得case值在组合逻辑中传递
(3) 如果有constant连接到多个port,在每个port前加buffer
请大牛们鉴定
发表于 2012-11-13 18:00:09 | 显示全部楼层
 楼主| 发表于 2012-11-15 09:48:01 | 显示全部楼层
回复 2# chrisyl
    哦,谢谢啊,,不过第二句我还是不大理解,能详细点吗?
发表于 2012-11-15 17:21:21 | 显示全部楼层
找本ICC的workshop看一下就清楚了 上面还有图解
 楼主| 发表于 2012-11-19 16:48:28 | 显示全部楼层
回复 3# damonzhao
    版主你好,第二条命令我还是不怎么明白,workshop上也没讲清楚,请版主指点指点我呀。
发表于 2012-11-19 18:00:20 | 显示全部楼层
When set to true, this variable enables constant propagation, even if a design
contains only logic constants. When set to false (the default), constant propagation
is not performed unless a set_case_analysis command is specified. The
disable_case_analysis variable overrides the case_analysis_with_logic_constants
variable. If the disable_case_analysis variable is set, no constants are propagated.
发表于 2012-11-19 20:50:59 | 显示全部楼层
student user guide上面有,你看看
 楼主| 发表于 2012-11-20 09:38:38 | 显示全部楼层
回复 7# damonzhao
    好的,我明白了。谢谢!
 楼主| 发表于 2012-11-20 09:39:38 | 显示全部楼层
回复 9# jrmjrf
    嗯,我知道了,谢谢你!
GMT+8, 2025-10-20 05:47 , Processed in 0.021688 second(s), 4 queries , Gzip On, Redis On.
