楼主: yuxueqiu123
[求助] 请教ICC中关于Timing Analasis的几个命令[已解决]
发表于 2014-10-3 10:12:14 | 显示全部楼层
也正在看这个问题,不错
发表于 2014-10-28 20:41:38 | 显示全部楼层
回复 1# yuxueqiu123
    -all
是指所有nets 包括constant吧
发表于 2017-2-21 16:54:52 | 显示全部楼层
谢谢你的分享
发表于 2017-2-22 02:34:42 | 显示全部楼层
Enables or disables analysis of multiple clocks that reach a single register.
Default value for this variable is ture.
This variable enables or disables analysis of multiple clocks that reach a register clock pin. When true (the default), all clocks reaching the register are analyzed simultaneously. When false, PrimeTime selects a random clock for analysis from among all clocks reaching a register clock pin. Do not change the value of timing_enable_multiple_clocks_per_reg from the default (true) unless you want this behavior.
If you set this variable to false and your design has multiple clocks per register, you should specify a clock to use withset_data_check -clock.
GMT+8, 2025-10-20 22:20 , Processed in 0.013094 second(s), 3 queries , Gzip On, Redis On.
