查看: 3059|回复: 3
[讨论] 锁存器和触发器的纠结
发表于 2012-7-23 17:36:21 | 显示全部楼层 |阅读模式
锁存器和触发器有什么不同,它们各自在哪种环境中更加可取?
参考答案如下:A latch allows input D to flow through to the output Q when the clock isHIGH. A flip-flop allows input D to flow through to the output Q at the clockedge. A flip-flop is preferable in systems with a single clock. Latches are pref-erable in two-phase clocking systems, with two clocks. The two clocks are usedto eliminate system failure due to hold time violations. Both the phase and fre-quency of each clock can be modified independently.
         但是不是很明白,需要高手指导一下。。。。
发表于 2012-7-24 10:26:15 | 显示全部楼层
等待大侠解释。呵呵
发表于 2012-7-25 09:58:29 | 显示全部楼层
电平触发和边沿触发的区别
发表于 2012-7-28 22:13:34 | 显示全部楼层
正解!
GMT+8, 2025-12-28 12:03 , Processed in 0.018380 second(s), 7 queries , Gzip On, Redis On.
