请教各位大虾:
小弟在综合的时候,SRAM的PIN的setup time的违例,让我无从下手。0.18的工艺,100M的频率。除了改RTL代码,大家平时都怎么解决呢?report如下:
Point Incr Path
clock CLKSCAN (rise edge) 0.00 0.00
clock network delay (ideal) 0.00 0.00
U_DSP/U_DSPCTR/Proc_cnt_reg_4_/CK (dfcrhq8) 0.00 0.00 r
U_DSP/U_DSPCTR/Proc_cnt_reg_4_/Q (dfcrhq8) 0.48 0.48 f
U_DSP/U_DSPCTR/U311/Y (inv0d32) 0.14 0.61 r
U_DSP/U_DSPCTR/U145/Y (or02d12) 0.23 0.84 r
U_DSP/U_DSPCTR/U302/Y (nd12d12) 0.19 1.04 r
U_DSP/U_DSPCTR/syn281/Y (nd03d12) 0.17 1.21 f
U_DSP/U_DSPCTR/U292/Y (xn02d8) 0.32 1.53 r
U_DSP/U_DSPCTR/Num_col[3] (DSP_CTRL) 0.00 1.53 r
U_DSP/Num_col[3] (DSP) 0.00 1.53 r
U_ACC_TOP/Num_col[3] (ACC_TOP) 0.00 1.53 r
U_ACC_TOP/U831/Y (inv0d32) 0.12 1.65 f
U_ACC_TOP/U936/Y (ckinvd40) 0.11 1.75 r
U_ACC_TOP/U459/Y (or02d12) 0.23 1.99 r
U_ACC_TOP/U768/Y (or02d12) 0.26 2.24 r
U_ACC_TOP/U553/Y (buffd32) 0.23 2.48 r
U_ACC_TOP/U212/Y (nd12d12) 0.18 2.66 r
U_ACC_TOP/U297/Y (an03d12) 0.23 2.90 r
U_ACC_TOP/U464/Y (an02d12) 0.18 3.08 r
U_ACC_TOP/U536/Y (an03d12) 0.25 3.33 r
U_ACC_TOP/U210/Y (mid02d8) 0.15 3.48 f
U_ACC_TOP/Acc_mux_out[9] (ACC_TOP) 0.00 3.48 f
U_DSP/Rawdata[9] (DSP) 0.00 3.48 f
U_DSP/U87/Y (buffd32) 0.20 3.68 f
U_DSP/U_BASE/Rawdata[9] (BASE) 0.00 3.68 f
U_DSP/U_BASE/U2033/Y (ckinvd40) 0.09 3.77 r
U_DSP/U_BASE/U1991/Y (nr02d12) 0.07 3.85 f
U_DSP/U_BASE/U1601/Y (nr02d12) 0.24 4.08 r
U_DSP/U_BASE/U2003/Y (nd02d12) 0.23 4.32 f
U_DSP/U_BASE/add_648/B[6] (BASE_DW01_add_14_2) 0.00 4.32 f
U_DSP/U_BASE/add_648/U0_2_6/Y (nr02d12) 0.24 4.55 r
U_DSP/U_BASE/add_648/U31/Y (buffd32) 0.20 4.75 r
U_DSP/U_BASE/add_648/U1_5_0_6/Y (nr02d12) 0.11 4.86 f
U_DSP/U_BASE/add_648/U64/Y (an02d12) 0.20 5.06 f
U_DSP/U_BASE/add_648/U53/Y (nd02d12) 0.17 5.24 r
U_DSP/U_BASE/add_648/U73/Y (nd02d12) 0.25 5.48 f
U_DSP/U_BASE/add_648/U138/Y (aoi21d8) 0.33 5.81 r
U_DSP/U_BASE/add_648/U147/Y (xn02d8) 0.29 6.10 r
U_DSP/U_BASE/add_648/SUM[10] (BASE_DW01_add_14_2) 0.00 6.10 r
U_DSP/U_BASE/U1917/Y (nd12d12) 0.14 6.25 f
U_DSP/U_BASE/U1211/Y (cknd02d16) 0.17 6.42 r
U_DSP/U_BASE/sub_308/B[10] (BASE_DW01_sub_14_2) 0.00 6.42 r
U_DSP/U_BASE/sub_308/U0_0_10/Y (inv0d32) 0.11 6.53 f
U_DSP/U_BASE/sub_308/U139/Y (nr02d12) 0.20 6.73 r
U_DSP/U_BASE/sub_308/U168/Y (nr02d12) 0.09 6.82 f
U_DSP/U_BASE/sub_308/U167/Y (nr02d12) 0.20 7.01 r
U_DSP/U_BASE/sub_308/U84/Y (nd02d12) 0.15 7.16 f
U_DSP/U_BASE/sub_308/U123/Y (inv0d24) 0.12 7.28 r
U_DSP/U_BASE/sub_308/U165/Y (oai21d8) 0.16 7.44 f
U_DSP/U_BASE/sub_308/U1_4_3_12/Y (aoi21d8) 0.21 7.66 r
U_DSP/U_BASE/sub_308/U0_5_13/Y (ckxr02d16) 0.35 8.01 f
U_DSP/U_BASE/sub_308/DIFF[13] (BASE_DW01_sub_14_2) 0.00 8.01 f
U_DSP/U_BASE/U2013/Y (cknd02d16) 0.13 8.14 r
U_DSP/U_BASU_DSP/U_BASE/U1187/Y (buffd32) 0.19 8.46 f
U_DSP/U_BASE/U1000/Y (inv0d32) 0.09 8.54 r
U_DSP/U_BASE/U1127/Y (cknd02d16) 0.14 8.69 f
U_DSP/U_BASE/U1205/Y (cknd02d16) 0.14 8.83 r
U_DSP/U_BASE/U1215/Y (inv0d32) 0.10 8.93 f
U_DSP/U_BASE/lt_573/A[4] (BASE_DW01_cmp2_13_1) 0.00 8.93 f
U_DSP/U_BASE/lt_573/U1_3_4/Y (inv0d24) 0.11 9.04 r
U_DSP/U_BASE/lt_573/U48/Y (nd02d12) 0.11 9.14 f
U_DSP/U_BASE/lt_573/U45/Y (oai21d8) 0.33 9.47 r
U_DSP/U_BASE/lt_573/U14/Y (aoi21d8) 0.20 9.67 f
U_DSP/U_BASE/lt_573/U36/Y (nd02d12) 0.16 9.83 r
U_DSP/U_BASE/lt_573/U21/Y (nd02d12) 0.12 9.95 f
U_DSP/U_BASE/lt_573/U6/Y (nd02d12) 0.12 10.07 r
U_DSP/U_BASE/lt_573/LT_LE (BASE_DW01_cmp2_13_1) 0.00 10.07 r
U_DSP/U_BASE/U1133/Y (or02d12) 0.19 10.26 r
U_DSP/U_BASE/U1545/Y (nd03d12) 0.21 10.47 f
U_DSP/U_BASE/U1635/Y (ckinvd32) 0.14 10.61 r
U_DSP/U_BASE/U847/Y (nd02d12) 0.12 10.73 f
U_DSP/U_BASE/U1115/Y (nd02d12) 0.14 10.88 r
U_DSP/U_BASE/U1870/Y (nd02d12) 0.19 11.07 f
U_DSP/U_BASE/U2017/Y (cknd02d16) 0.18 11.25 r
U_DSP/U_BASE/U1943/Y (oai2m1d8) 0.19 11.44 f
U_DSP/U_BASE/U849/Y (nd03d12) 0.23 11.66 r
U_DSP/U_BASE/U751/Y (nd03d12) 0.25 11.91 f
U_DSP/U_BASE/U1664/Y (inv0d32) 0.15 12.06 r
U_DSP/U_BASE/U2007/Y (nd02d12) 0.12 12.18 f
U_DSP/U_BASE/U1542/Y (nr02d12) 0.19 12.37 r
U_DSP/U_BASE/U1941/Y (oai2m1d8) 0.15 12.52 f
U_DSP/U_BASE/U_BASEBUF/DIN[17] (RFSP256X20M4) 0.00 12.52 f
data arrival time 12.52
clock CLK24 (rise edge) 10.00 10.00
clock network delay (ideal) 0.00 10.00
clock uncertainty -0.30 9.70
U_DSP/U_BASE/U_BASEBUF/CLK (RFSP256X20M4) 0.00 9.70 r
library setup time -0.31 9.39
data required time 9.39
data arrival time -12.52
slack (VIOLATED) -3.13
组合逻辑确实太多了些,不知有没通过sdc约束修正的可能? |
