查看: 2895|回复: 0
[求助] 0120711
发表于 2012-7-11 10:29:24 | 显示全部楼层 |阅读模式
我是用FPGA驱动 直流无刷电机,
用霍尔传感器去捕捉电机转子的转动状况,从而控制如何驱动三相电流换相,
霍尔传感器是181 的霍尔开关,驱动马达时候发现马达转动仍有杂音,
接收霍尔信号时候,用了一个case 语句,有default 的时后,我选着给默认状态
PWM输出全部拉低,不驱动马达,烧录硬件后,马达转动,噪音仍有,消不掉,但较为小,
但是去掉默认状态后,马达转动磕磕绊绊,非常不理想,
现在硬没有上位机,观察信号很不方便,思考中,望指点
  望有经验的人指点一下
case({hall_a,hall_b,hall_c})
         3'b110:
                begin
                pwm_3_h<=clk_20k;
                pwm_3_l<=1'd0;
                pwm_2_h<=1'd0;
                pwm_2_l<=1'd0;
                pwm_1_h<=1'd0;
                pwm_1_l<=clk_20k;
                end
         3'b100:
                begin
                pwm_3_h<=clk_20k;
                pwm_3_l<=1'd0;
                pwm_2_h<=1'd0;
                pwm_2_l<=clk_20k;
                pwm_1_h<=1'd0;
                pwm_1_l<=1'd0;
                end
         3'b101:
                begin
                pwm_3_h<=1'd0;
                pwm_3_l<=1'd0;
                pwm_2_h<=1'd0;
                pwm_2_l<=clk_20k;
                pwm_1_h<=clk_20k;
                pwm_1_l<=1'd0;
                end
         3'b001:
                begin
                pwm_3_h<=1'd0;
                pwm_3_l<=clk_20k;
                pwm_2_h<=1'd0;
                pwm_2_l<=1'd0;
                pwm_1_h<=clk_20k;
                pwm_1_l<=1'd0;
                end
         3'b011:
                begin
                pwm_3_h<=1'd0;
                pwm_3_l<=clk_20k;
                pwm_2_h<=clk_20k;
                pwm_2_l<=1'd0;
                pwm_1_h<=1'd0;
                pwm_1_l<=1'd0;
                end
         3'b010:
                begin
                pwm_3_h<=1'd0;
                pwm_3_l<=1'd0;
                pwm_2_h<=clk_20k;
                pwm_2_l<=1'd0;
                pwm_1_h<=1'd0;
                pwm_1_l<=clk_20k;
                end
                  default:
                begin
                pwm_3_h<=1'd0;
                pwm_3_l<=1'd0;
                pwm_2_h<=1'd0;
                pwm_2_l<=1'd0;
                pwm_1_h<=1'd0;
                pwm_1_l<=1'd0;
                end
        endcase
GMT+8, 2025-12-29 09:47 , Processed in 0.018848 second(s), 7 queries , Gzip On, Redis On.
