查看: 3519|回复: 2
[求助] DC求救
发表于 2012-3-9 08:57:36 | 显示全部楼层 |阅读模式
DC综合是时,导入代码出现这样的错误Error:  /data/tangyt/dc_text/xfab_xo035design/clkdiv/1.v:37: The statements in this 'always' block are outside the scope of the synthesis policy. Only an 'if' statement is allowed at the top level in this always block. (ELAB-302)。该怎么解决
*** Presto compilation terminated with 1 errors. ***
发表于 2012-3-9 16:01:36 | 显示全部楼层
这个文件的37行,有个always块,你在这里面写的东西违反了语法。
 楼主| 发表于 2012-3-9 16:23:00 | 显示全部楼层
回复 2# acgoal
    谢谢版主,已经解决了,状态机中少加了begin,end
GMT+8, 2025-12-20 15:14 , Processed in 0.017359 second(s), 5 queries , Gzip On, Redis On.
