查看: 4565|回复: 3
[求助] synthesis problem
发表于 2012-2-3 19:38:08 | 显示全部楼层 |阅读模式
TSMC 90nm SRAM has signal EMA[2:0], when i use SRAM, i set EMA=3'b000,
SRAM_DP_ADV SRAM_i0 (
               .CLKA(CLKA),
               .CENA(CENA_n),
               .WENA(WENA_n),
               .QA(QA_n),
               .DA(DA_n),
               .AA({3'b000,AA_n}),
               .EMAA(3'b000),
               .CLKB(CLKB),
               .CENB(CENB_n),
               .WENB(WENB_n),
               .QB(QB_n),
               .DB(DB_n),
               .AB({3'b000,AB_n}),
               .EMAB(3'b000)
according to lib file, when reading SRAM, address to valid read-data is about 1.6,
         bus(QA)   {
                bus_type : SRAM_DP_ADV_DATA;
        direction : output;
        max_capacitance : 0.360;
                memory_read() {
            address : AA;
                timing() {
                        related_pin :   "CLKA" ;
                        timing_type : rising_edge;
                        timing_sense : non_unate;
                        when : "(!EMAA[2]) & (!EMAA[1]) & (!EMAA[0])";
                        sdf_cond : "EMAA[2] == 1'b0 && EMAA[1] == 1'b0 && EMAA[0] == 1'b0";
                        cell_rise(SRAM_DP_ADV_mem_out_delay_template) {
                        index_1 ("0.041, 0.067, 0.096, 0.155, 0.329, 0.619, 1.000");
                        index_2 ("0.001, 0.012, 0.024, 0.048, 0.120, 0.240, 0.360");
                        values ( \
                          "1.676, 1.686, 1.698, 1.720, 1.788, 1.901, 2.014", \
                          "1.677, 1.687, 1.698, 1.721, 1.789, 1.902, 2.015", \
                          "1.678, 1.688, 1.699, 1.722, 1.790, 1.903, 2.016", \
                          "1.680, 1.690, 1.701, 1.724, 1.792, 1.905, 2.018", \
                          "1.685, 1.696, 1.707, 1.729, 1.797, 1.910, 2.023", \
                          "1.695, 1.705, 1.716, 1.739, 1.807, 1.920, 2.033", \
                          "1.707, 1.717, 1.729, 1.751, 1.819, 1.932, 2.045" \
but dc synthesis report show:
  Point                                                   Incr       Path
  clock CLK (rise edge)                                   0.00       0.00
  clock network delay (ideal)                             0.00       0.00
  tposemem/Bisted_DPR64x16/WRAPPED_RAM_i0/SRAM_i0/CLKA (SRAM_DP_ADV)
                                                          0.00       0.00 r
  tposemem/Bisted_DPR64x16/WRAPPED_RAM_i0/SRAM_i0/QA[5] (SRAM_DP_ADV)
                                                        999.00     999.00 r
I guess when synthesis, dc choose the worst sdf_condition
                timing() {
                        when : "(EMAA[2]) & (!EMAA[1]) & (!EMAA[0])";
                        sdf_cond : "EMAA[2] == 1'b1 && EMAA[1] == 1'b0 && EMAA[0] == 1'b0";
                        values ( \
                          "999.000, 999.000, 999.000, 999.000, 999.000, 999.000, 999.000", \
                          "999.000, 999.000, 999.000, 999.000, 999.000, 999.000, 999.000" \
how to solve it
发表于 2012-2-3 21:41:12 | 显示全部楼层
在报告里看看net的load是不是太大
发表于 2012-2-3 22:27:36 | 显示全部楼层
设置下 high_fanout相关参数
发表于 2012-2-5 00:03:04 | 显示全部楼层
EMA 的设置有特殊讲究的,看前面的帖子,
GMT+8, 2025-12-19 10:28 , Processed in 0.022126 second(s), 8 queries , Gzip On, Redis On.
