查看: 49331|回复: 105
[2 patchs][SpringSoft] [laker] [201106] [crack]
发表于 2011-12-29 16:27:58 | 显示全部楼层 |阅读模式
Springsoft Laker 201106 patchs for linux + linux64
[type] patch
[Company Name] SpringSoft
[file name]  Laker2011.06
[Version]  201106
linux 32 bits patch
patch_laker201106.rar (275 Bytes , 下载次数: 509 )
linux 64 bits patch
patch_laker201106_64.rar (276 Bytes , 下载次数: 525 )
发表于 2011-12-29 17:10:32 | 显示全部楼层
xie xie
发表于 2011-12-29 17:44:33 | 显示全部楼层
请问楼主:SFK执行文件在哪儿?
发表于 2011-12-29 18:31:12 | 显示全部楼层
没有32位的软件啊~~
发表于 2011-12-29 18:48:33 | 显示全部楼层
thanks...
发表于 2011-12-29 19:01:45 | 显示全部楼层
终于找到了啊,感谢楼主分享
发表于 2011-12-29 19:33:50 | 显示全部楼层
能稳定运行吗?别用了一半,就自动退出啊。laker的这个问题不管是license还是暴力破解总是有这个问题。
还是等高人试用过后再下载吧。
发表于 2011-12-29 23:26:10 | 显示全部楼层
感谢楼主分享.
但只能 read, 无法 edit!
 楼主| 发表于 2011-12-30 08:43:46 | 显示全部楼层
Sorry, I am not very good at Laker. I just try to solve license problem for some say that their laker license would be expired on 2011/12/31. I develop the patch with a small simple GDS. I could read, edit, save input stream. No any problem. And stable at least several hours (> 12 hours, I didn't test for more time yet).  Could you describe your problem more clear? I would like to make my patch to be a usful patch for most cases.
    For sfk, you could easy find it by searching the internet. It is a free, open tool. linux, windows version are available.
    I also find someone had posted laker201106 on eetop. You could easy find it. But I didn't know whether it is OK or not. If it is not OK, I would try to help.
Happy New Year
 楼主| 发表于 2011-12-30 08:53:47 | 显示全部楼层
回复 7# liude19832006
    This problem is caused by patching the code on the higher license check function. You could say it is a trap. This trap would let you execute for a while then exit later. I am confident that my patch SHOULD have solved this problem.
GMT+8, 2025-12-23 16:57 , Processed in 0.027647 second(s), 7 queries , Gzip On, Redis On.
