楼主: joseCAD
[2 patchs][SpringSoft] [laker] [201106] [crack]
发表于 2011-12-30 09:15:36 | 显示全部楼层
我想 laker 可惜没有 license 。
发表于 2011-12-30 09:15:52 | 显示全部楼层
Need lnx 32 bit version
发表于 2011-12-30 11:46:42 | 显示全部楼层
楼主高人啊。佩服佩服。问一个问题,针对2009、2010的版本应该也可以使用吧?
另外就是对laker ADP、laker AMS也应该可以使用吧,毕竟三个软件的检查license的
机制应该是一样的的。
 楼主| 发表于 2011-12-30 12:05:30 | 显示全部楼层
Sorry, I just test Laker version 201106. I don't know whether other versions are OK or NOT.
Per different versions, patch location might be the same. BUT the real code might be a little different.
发表于 2011-12-30 13:04:38 | 显示全部楼层
Is there any workable license file for this??
 楼主| 发表于 2011-12-30 14:06:02 | 显示全部楼层
是不是还需要一个license文件啊?
我按照附件破解后,启动laker,显示
*ERROR* License checking failed, ...
Guest from 58.251.134.x 发表于 2011-12-30 13:58
    You are NOT patching successfully.
发表于 2011-12-30 14:41:46 | 显示全部楼层
謝謝分享!
***2012/01/04回報
經測試結果~這個p@tch只針對201106版本友和諧作用~
謝謝!
发表于 2011-12-30 15:06:05 | 显示全部楼层
可是patch 的时候 已经显示 1files checked, 1 changed
 楼主| 发表于 2011-12-30 15:50:13 | 显示全部楼层
If your laker version is exactly laker 2011.06 LINUX (32) version. copy patch_laker201106 to <laker_installed_dir>/platform/LINUX/bin . Then run the patch. You should get
[total hits/matching patterns/non-matching patterns]
[002/2/0] laker
1 files checked, 1 changed.
Then you could execute laker without any license setting.
发表于 2011-12-31 11:00:21 | 显示全部楼层
patch 的时候 已经显示 1files checked, 1 changed,
启动laker,显示
*ERROR* License checking failed, or the maxium number of licensed users has benn reched
GMT+8, 2025-12-24 10:56 , Processed in 0.019671 second(s), 3 queries , Gzip On, Redis On.
