楼主: joseCAD
[2 patchs][SpringSoft] [laker] [201106] [crack]
发表于 2012-3-24 01:44:42 | 显示全部楼层
呵..這版的laker我還沒有
发表于 2012-4-4 12:08:37 | 显示全部楼层
Hi JoseCAD , laker command is ok, but when i run gdsIn or gdsOut it says can't find license.
So i think those two command not be crack , can you provide patch file ?
发表于 2012-4-17 12:12:11 | 显示全部楼层
Dear joseCAD
我下載您在另一篇 "[原创] [25 parts,15mb/part][SpringSoft] [Laker] [201106][32+64 bits][crack]" 的LAKER,這應該是201106的版本,是嗎?
但是我將patch_laker201106放在~/Laker201106/platform/LINUX/bin,底下,執行
[root@abc bin]#./patch_laker201106
結果是以下
[root@abc bin]# ./patch_laker201106
./patch_laker201106: line 3: sfk: command not found
請問,是因為沒有skf file 嗎?
再來就是,使用這個patch,有需要先設定*.cshrc file嗎?
還是只要把patch_laker201106丟進相對應的地方就可以
麻煩您幫個忙,解答一下,謝謝。
有沒有什麼地方是我遺漏的,由於一直都是使用CADENCE,想試試看LAKER
所以麻煩您幫忙解答,謝謝。
发表于 2012-4-17 13:52:32 | 显示全部楼层
可以用了,只要把patch_laker201106裡面的sfk前面加上./,就可以了,謝謝
 楼主| 发表于 2012-4-18 17:06:54 | 显示全部楼层
回复 58# tobacoo
    gdsIo patch is added into original patch rar. download it again. And try.
发表于 2012-4-18 19:04:47 | 显示全部楼层
回复 1# joseCAD
dear joseCAD belive that your crack donot workk..help us please..
i change the first line sfk with ./sfk of your crack and add sfk to /INDIRLAKER/platform/linux_x64_bin and patched it but it is only patch 2 file (laker and gdsOut) but it is not work..
it need license..
 楼主| 发表于 2012-4-19 09:11:54 | 显示全部楼层
Dear joseCAD
我下載您在另一篇 "[原创] [25 parts,15mb/part][SpringSoft] [Laker] [201106][32+64 bit ...
barry0518 发表于 2012-4-17 12:12
    Yes. You need to install sfk first. sfk is free. Searching the internet.
Besides, you don't need to setup any env. variable except the PATH.
set path = ( <laker_installed_dir>/bin $path)
That's all.
 楼主| 发表于 2012-4-19 09:15:11 | 显示全部楼层
回复  joseCAD
dear  belive that your crack donot workk..help us please..
i change the first l ...
molteza 发表于 2012-4-18 19:04
    I try it again. It should be working. Be sure you do everything right. There is someone write a detail patch step which tell you how to use my patch. That is very good. You could reference it.
发表于 2012-5-1 00:45:09 | 显示全部楼层
Thank......
发表于 2012-8-10 07:58:16 | 显示全部楼层
GMT+8, 2025-12-24 04:18 , Processed in 0.018320 second(s), 3 queries , Gzip On, Redis On.
