楼主: joseCAD
[2 patchs][SpringSoft] [laker] [201106] [crack]
发表于 2012-1-1 03:39:58 | 显示全部楼层
thank you
发表于 2012-1-1 03:44:22 | 显示全部楼层
thank you for creating the patch
 楼主| 发表于 2012-1-2 09:36:27 | 显示全部楼层
回复 21# cchsu_ushcc
    Make sure your laker are version 2011.06. copy the related patch to <laker_installed_dir>/platform/LINUX/bin. or <laker_installed_dir>/platform/LINUX64/bin ( for 64 bits). run the patch. it shoud be
[total hits/matching patterns/non-matching patterns]
[002/2/0] laker
1 files checked, 1 changed.
then you can execute laker without any license setting.
发表于 2012-1-2 10:27:50 | 显示全部楼层
thanks...
发表于 2012-1-3 14:33:06 | 显示全部楼层
Does it work for 2011.06p1??
发表于 2012-1-4 08:59:51 | 显示全部楼层
发表于 2012-1-4 10:10:15 | 显示全部楼层
thanks for your kindly sharing!!
发表于 2012-1-5 17:05:53 | 显示全部楼层
I have 3 problems, please help me, thanks a lot.
1. I try version 2011.06RV from "http://bbs.eetop.cn/viewthread.php?tid=310580&highlight=laker". But I get "2011.02p3" when I run laker, so your patch can work for this version? My linux is RHEL4.8-64bit.
2. I also get error "License checking failed, or the max....".
3. As I try <...>/platform/LINUX64/bin/laker, it seems that my linux miss libQtSolutions_MotifExtension-2.7.so.1
Thanks!
 楼主| 发表于 2012-1-6 08:18:36 | 显示全部楼层
回复 28# tao0407
    My patch is working ONLY for laker 2011.06. It would NOT be able to patch other versions.
You should set your path to <laker_installed_dir>/bin . The laker would call the real execution file according to your platform.
.. So 201106RV is not real version of 2011.06 64 bits ? I didn't know about this.
发表于 2012-1-6 10:16:47 | 显示全部楼层
for 64 version"platform/LINUX64"
works, no need licence check. thanks
GMT+8, 2025-12-23 18:55 , Processed in 0.018764 second(s), 3 queries , Gzip On, Redis On.
