Fractional/Integer-N PLL Basics (TI)
Edited by Curtis Barrett Wireless Communication Business Unit
Contents
Introduction to Phase Locked Loop (PLL) ....................................4
Frequency Synthesis ..............................................................5
Digital PLL Synthesis ..............................................................5
PLL Components ......................................................................8
Voltage Controlled Oscillators (VCO)..........................................8
Phase Frequency Detectors (PFD)............................................11
Dividers ................................................................................13
Loop Filter.............................................................................14
The Simple Math of PLL.............................................................14
Feedback Loop Analysis..........................................................15
Loop Transfer Function...........................................................17
Loop Filter Design....................................................................17
Natural Frequency and Loop Bandwidth....................................18
Passive Loops and Charge Pump..............................................21
Lock-up Time and Speed Up ...................................................23
Loop Order and Type..............................................................24
Loop Stability and Phase Margin ..............................................24
Active and Passive Loops Summary..........................................25
Modulation ............................................................................26
Integer-N PLL...........................................................................27
Concept ................................................................................27
Basic Operation ......................................................................29
Functional Description .............................................................29
Advantages and Limitations......................................................31
Fractional-N PLL .......................................................................31
Concept ................................................................................31
Functional Description ............................................................32
Divider Dynamics ...................................................................32
Fractional Accumulator ...........................................................33
Fractional Spurious Signals and Compensation ..........................34
Advantages and Limitation.......................................................39
Comparison...........................................................................39
Phase Noise..............................................................................40
Definitions and Conversions .....................................................41
Division and Multiplication Effect................................................43
Phase Noise Measurements......................................................43
The Noise Distribution Function L(fm).......................................44
Noise Sources in PLL ..............................................................44
Spurious Suppression................................................................46
Reference Spurious Signals .....................................................46
Fractional Spurious Signals ......................................................47
Spurious Signal Suppression....................................................47
The Effect of Phase Noise on System Performance......................47
Loop Response Simulation ........................................................48
Multi-Loop Design ..................................................................48
Measurements Techniques.........................................................49
Phase Noise...........................................................................49
Spurious Signals ....................................................................50
Switching Speed ....................................................................50
The TI Family of PLL ASICs........................................................51
Summary and FAQ ..................................................................52
Glossary..................................................................................53
References and Further Reading.................................................54 |
