查看: 1928|回复: 0
[招聘] Cadence SH招聘Lead/Senior Customer Engagement Engineer
发表于 2015-3-19 09:58:20 | 显示全部楼层 |阅读模式
Title: Lead/Senior Customer Engagement Engineer
Position Description:
1. Work in shanghai Silicon Signoff and Verification (SSV) electrical PE team, focus on Tempus Timing Signoff System & Quantus  Extraction System (Cell level).
2. Support key customer engagements and local AEs to help on the business increase.
3. Working as a domain expert to well communicate with customers for their valuable feedbacks
4. Co-work closely with R&D team to enhance the tool based on customers' real demandings
Position Requirements:
1. Master with 3+ years working experience or Bachelor with 5+ years experience.
    IC design background, Cadence Encounter platform experience will be a plus
2. Digital design and analysis experience is necessary, STA and postRoute timing closure will be desired
3. Working experience with foundry, libraries, tech files; spice models are desired
4. Product Engineering and customer supporting experience is desired.
5. Good communication in English and Chinese, good confidence and good self-motivation.
6. Good team spirit, well-aligned with the "One Cadence, One Team."
If you have interest, PLS send your update CV to zhangyl@cadence.com
GMT+8, 2025-12-10 04:10 , Processed in 0.015288 second(s), 6 queries , Gzip On, Redis On.
