查看: 2392|回复: 3
[求助] FPGA综合时的错误
发表于 2011-11-25 11:20:25 | 显示全部楼层 |阅读模式
always @(posedge wr_clk or posedge reset)
begin
sche_info_in_dl1<=sche_info_in;
end
这是往模块中写的,sche_info_in是外界的输入,然后往模块中寄存了一下,为什么综合时提示The logic for <sche_info_in_dl1> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release???
发表于 2011-11-25 12:11:56 | 显示全部楼层
你的reset信号没有用到,无法综合成一个已知的带异步复位的触发器,建议写成
begin
if (reset)
   sche_info_in_dl1<=0;
else
end
发表于 2011-11-25 22:49:49 | 显示全部楼层
begin
end
楼主,请问你能想象出来这是个什么样子的器件吗?
发表于 2011-11-26 10:40:57 | 显示全部楼层
2#正解
或者把异步复位or posedge reset去掉,直接寄存
GMT+8, 2025-12-24 17:06 , Processed in 0.032134 second(s), 6 queries , Gzip On, Redis On.
